Help needed with opening frequencies on satellite
peglegpete
TMat 1500 1.2 channle dish Diablo cam trex cam. Medion computer
Rainham Essex
Hi All
I have a TM nano SEM2 plus. I would like to open channel on satellite 9 east. I have channel 9 east but they are all coming up as dark, I have tried to open then but cannot. I know its on 9 east, my satellite meter reads to tell me its on it. Can someone tell me how to open them (step by step if you can). I have a 1.2 channel master motor dish but if I need to put a new channel on the satellite, I do not know how to put the frequencies in so would need help with that too.
Thank you for any help you can give.
regards
Peglegpete
Which channels are you looking for? If by "opening" "dark" channels you mean decrypting scrambled channels then we can't and won't help you with that here.
Assuming the box has no blind scan, you'll need to add a transponder with the frequency, polarisation and symbol rate of the channels you are looking for. The manual should help with this.
What meter are you using?
TM nano SEM2 plus like a lot of TM receivers has had no software updates for a few years now as Technomate has dropped out of the market,
Your best bet is to get one of these new multi stream receivers just google multi stream satellite receivers.
Are you getting any channels at all on the satellite ?
peglegpete
Rainham Essex
Hi All
regards
Peglegpete
Eutelsat 9e All the channel are Dark M 2 Freq 11958 v 30000 3/4 is a Free to air Channel it is Dark the all the channel are dead if I get them to ligh up the satellites will come a live
Mickha
North West
11958 V on 9E is listed as 27500, not 30000, which indicates that you've either gotten something wrong, or your dish isn't pointed at 9E.
Have you tried a blind scan and got any FTA channels opening?
https://www.lyngsat.com/Eutelsat-9B-and-Ka-Sat-9A.html
peglepete - your profile lists 2 obsolete cams. Dont bother trying to use them - they are useless nowadays. They days of having multiple encrypted services open on cams are LONG gone
peglegpete
Rainham Essex
Satellites that open are 52e 46e 42e 28e 26e 19e 16e 13 e 10e 7e 4.8 e 7w 30w.I can all free to air on these .Alsat V Box .Is the one one to moves the Dish i have all the Degrees printed.The ones I am unable to open are all black with no signal on the Channel. But signal on the meter I have the degrees for them thank to my Echostar The meter is Televes you said to change my box as it not update. I am unable to put osram in or use USB.Because I don,t know to put fat on 32 on it.I trying to find William 1 satellites which is free to air. It use to be on Alsat I can get in the site can,t open any thing since changes were made
to open
If you can receive 10e then you will be able to receive all the stronger transponders from 9e at the same time.
Mickha
North West
You format a USB stick, to FAT 32, before putting anything on it.
You do this using your PC, if using Windows, connect your USB stick, to your PC, open up my PC, right click, on the USB drive, select Format, select the FAT 32 option, and then click start.
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Last time I checked 9E there wasn’t much available that was FTA. Is there a specific channel you want to view?
peglegpete
Rainham Essex
Ma Sport Hungary 11958 V 27500 2/3. I would like to open all my dark satellites channel on my box
Not sure what you are doing wrong but that one is fta:
Presumably you have a setting wrong somewhere.
I'd guess that the 9e position isn't stored correctly on the vbox.
Add the the 9e transponders you want to the 10e transponder list, then scan.
