hotbird with 65cm dish
cia.kelly
Dish: ASC Signal "Channel Master" 120 cm.
LNB: Invacom QDF-031 with Channel Master feed horn.
Box: Humax Foxsat-HD
Stockholm
hi all
i live in belfast, n ireland. do you think i can use a 65 cm dish to receive hotbird 13E
thx
mpaiva
casa
spain
cia.kelly said:
hi all
thx
Have a look here: h**p://www.satellitesuperstore.com/hot.htm
I think the dish should have at least 1,00 meter.
In Northen Portugal we use an 0,85 cm dish and is ok.
Price of dish between 0,65 and 1,00 is very small. Só get the big one, that's my opinion and put a support for a double Lnb so that you can see both satellites ASTRA and Hotbird as well.
Hope you get it right.
No, 65 cm should be fine for Ireland, particularly Belfast which is on the eastern side.
1m is complete overkill for Northern Ireland.
Even a zone 1 minidish will be plenty big enough unless it rains heavily!
Edit - have to type faster!
Something around 80 cm would be needed if the OP wants 13E and 19E on one dish :)
cia.kelly
Stockholm
hi rolfw,
know it's a stupid question but how does your map work? the numbers get less as you go further out, how does that equate to dish size?
The signals are strongest near the centre of the coverage area. The numbers are downlink powers in dBW
Use this page to give you an idea of required dish size when you only have powers:
http://www.flysat.com/dish.php
cia.kelly
Stockholm
cheers analoguesat/rolfw
for the quick responses!
mpaiva
casa
spain
I thank all friends that have given their best ideas, but, I would choose a dish of 1,00 meter at least, because i'ts easier to direct and get the sats signals, and also because when it rains in small dishes we loose the image.
Why shell we try to save 2, or 3 pounds in a dish. Price differences between a small and medium dish is so...
Sorry friends if my English is not good enogh . I'm Portuguese and only lived in England for a short time.
Hope that you get the right thing and feel pleased with it.
A larger dish is HARDER to align because of the narrower boresight (acceptance angle) of larger dishes
:D :D
mpaiva
casa
spain
:D :D
You may be right, but my experience showed me that with larger dishes I could get to the sat faster then with small dishes.
But I'm an amateur that only do it for me and a friend.
We used a sat finder named "digisat Pro Accu" which is very good.
LinK:h**p://www.servico-tecnico.com/portugues.html
