How to receive a satellite channel with no SID?
A.h. king
Hi
Middle East
Does anybody know how can I receive a satellite channel that doesn't have an SID? And I don't have on my receiver PID scan.
What on earth are you trying to receive?
A.h. king
Hi
Middle East
There is a channel on Express AM22 with no SID, when I search for it on the receiver I don't get, but on the internet it is said that it exists. What should I do?
What Channel is it?
Not sure you can ............. Flysat says it is hidden (not in Programme Map Table) and requires manual PID entry.
What Receiver are you using? (It's helpful to keep an up to date kit list under your User Profile)
Are you sure you cannot create a "User Channel"?
You need to put the pids in manually. If your receiver doesnt allow that then you cant watch it.
Trust
Nijmegen Netherlands
there is a program "SIDFinder_v1.0.6"
Maybe it works for you .
If you use an Enigma based receiver, you could try loading pre-set channel lists. I have this channel in my list already and it works (haven't tried scanning it though).
BlindFaith
TBS 5925
scanning won't be successful. There is no SI referring to the elementary streams ;) You have to define this channel manually. How, depends on your receiver/application.
A.h. king
Hi
Middle East
And what does this program do? And how would it help me?
A.h. king
Hi
Middle East
Thank you guys for all your help!
The channel resolved on a DR.HD F15.
Trust
And what does this program do? : maybe its called sidfinder because it can find sids !!
And how would it help me? : I understood that you wanted to know the sid for that channel !!
I never tried it , but maybe it can .
A.h. king
Hi
Middle East
Thanks but the channel I'm trying to receive doesn't have an SID and doesn't appear when I scan and my receiver doesn't support PID scan
A.h. king
Hi
Middle East
What type of satellite receiver did you use in this screenshot?
Its in his reply and your quote ;)
A.h. king
Hi
Middle East
Does DreamSky DSR-3000 have a PID scan/search?
Have a look through the menu structure - thats an obscure receiver here in Europe, and the chances of one of our regular members having seen one let alone used one is remote.
If it does its probably somewhere in or around the manual search settings.
