humax set up, and post code.
silverback-1
Comag portable 12 volt
HP pavilion dv 9000
merseyside england
Hi all I have just bought the humax foxsat -hd and I have been trying to set it up.I have visited the web site that gives you all the co-ordinates including the obstacle table as there are high trees in my direct line and according to the table I should have cleared them but a telivision aerial installer doubts it. Also when entering the correct post code the message comes back not a valid post code ,but it is, how does this effect the set up proceedure, last question should the dish be true vertical, I would appreciate any help. Colin.
satelliteman
Also when entering the correct post code the message comes back not a valid post code ,but it is, how does this effect the set up procedure
Find a close enough postcode for your area. This relates to the BBC/ITV regions listed on the EPG :)
Maybe a little more info required regarding the set up.
silverback-1
HP pavilion dv 9000
merseyside england
my location is a caravan site in Formby Merseyside I have taken exact compass possitions on a dish with a good reception about 50 meters from mine the only difference is he has not got trees quite as high as the ones behind me, on the obstacle website I mentioned I have put in the distance of the trees and the table says the trees would have to be about 12 meters high to be in the way but my box does not locate the satellite. Colin
If you are attempting to align the dish by compass bearings alone, you will probably be unsuccessful Colin. You should get yourself a little satbeeper type meter, also what make of dish and LNB are you using, some pictures would be helpful.
silverback-1
HP pavilion dv 9000
merseyside england
[fieldset=Admin]Please do not link to images upload them here, I have uploaded for you[/fieldset]
Hi the dish is one that I had given to me it measures about 90cm x 60cm the LNB is a brand new Thompson quad bought off ebay, cheers Colin
silverback-1
HP pavilion dv 9000
merseyside england
hi my dish was given to me and it measures about 90cm x 60cm, the lnb is a brand new thompson quad bought off ebay
silverback-1
HP pavilion dv 9000
merseyside england
should the info in green be measured from the top vertical to the angle of 61 degrees
sorry if I`m doing somthing wrong the only way I know how to place a photo is with photobucket
