latest pet 123 humax channel settings modified for h to h mounts
phillpayne
humax 5400z patched to hot 11.1, v box mrk2, 1.1m triax dish, jeager 12" activator .6 lnb, modified pet123 settings
kent
latest 05/11/07 files included for toh 2.3 and for toh 3
PLEASE NOTE, USERS OF TOH 3.2 HOT UPWARDS AFTER UPLOADING SETTINGS, CHANGE CAID PRESELECT TO CARD+EMU, AND RELOAD KEYS, IN THAT ORDER.
also checkout how pet123 has organised the fta channels
WARNING ITS ADVISED
do not edit any channels, in anyway, on screen, this has a tendency to cause the rA and three dots problem, and means you have to reload the settings again.
If you wish to edit the channels, do so by all means but do it within the editor of your choice, before loading to the stb, to avoid this problem.
hope this avoids some future problems
hi all,
pet 123 has now changed his settings to include the motor adjustments that i was making, also they include txts of mine in their settings file, so i am still reproducing the files, with other adjustments.
the file is as put out by pet123 but with my twiddles, and included is a folder of my txts.
as always look at
w.w.w.humaxsettings.nl
for info of updates
please note that all the antennas have toh 3 position No's and names
regards
  • modified pet123+h to h mounts051107.zip
Thanks Phil, much appreciated. :)
Test post for notification
hotice
Thanks phillpayne for your file It save a lot of time cheers hotice
Thanks Phil and a happy new year mate. :)
phillpayne
kent
hi rolf,
the same to you mate, and i hope its better than the last:-googly
regards
phil
phillpayne
kent
hi all,
for all who use these files, pet123 has gone away for a couple of months, so there will be no updates until he returns, sorry
regards
phil
phillpayne
kent
hi all,
latest from pet123 is december sorry
phil
phillpayne
kent
latest pet123 19/07/07
phillpayne
kent
all updated 05/11/07
