Move CAM and Card to another receiver
timhan
Technomate 5400 CI+ USB,
105cm Gibertini dish,
Smart Titanium LNB (0.2 db); FloppyDTV (2) in HTPC.
Amsterdam, Netherlands
We are moving offices at work and so I have use of a subscribed Canal Digitaal cam and card for a few weeks before the dish is put up at the new location. What do I need to do to be able to use the card in my receiver? In the office, there is some off-brand cheapy receiver that it works in and and home I have a Technomate TM-5400 CI+ USB.
Do I need to do anything to match the cam or card to the receiver so that it works?
Thanks much!
Mickha
North West
Just insert the Cam into the CI slot on your receiver, it might even work in the card slot, if your receiver has one.
You will need to ensure that you have all the Canal Digitaal channels scanned in.
Jan Luc Piccard
No setup
Netherlands
It should work with the latest firmware according the info I have but to be honest I can't check it.
