garym71
- Aug 7, 2007
- Age
- 52
- Pace TDS470N Sky+ Receiver, Technomate TM-5400CI+ FTA Receiver, Raven Gemini 70cm Mesh Dish with East & West offset LNB brackets, 2 x Inverto Black Ultra Single LNBs, Inverto Black Premium Quad LNB, Eurostar 4x1 DiSEqC Switch, Webro WF100 Cable
- South Oxfordshire, UK
Here are a few pictures of my setup. It's not a motorised system so it's fairly basic compared to some of the other members systems but it was my first self-installed system so it was a good learning exercise The dish went up a couple of weeks ago and the whole setup was finally completed last weekend.
These are the specifications of my system:-
The elevation bracket on the back of the dish was originally galvanised silver in colour so I painted it dark grey to match the dish as I thought it looked much better I also modified the LNB arm by cutting a hole in the front of it so I could run the cables inside the hollow tube as opposed to them having to be taped along the outside which made the installation look much neater
The dish is centred with a single ouput LNB pointing at Astra 19.2E. The quad output LNB on the east offset bracket is pointing at Astra 28.2E, and the other single output LNB on the west offset bracket is pointing at Hotbird 13.0E.
I have both single LNBs and one of the outputs from the quad LNB going to a DiSEqC switch. The output of the switch currently goes to a Technomate TM-5400CI+ FTA Receiver. Two of the remaining outputs from the quad LNB (Astra 28.2E) go direct to a Sky+ box.
I'm getting pretty good signal level & quality results from all 3 satellites as can be seen in the attachments below.
Thanks to everyone on here who gave me help and advice when I needed it
- Raven Gemini 70cm Mesh Dish
- Raven Multi-LNB Holder Offset Brackets (both East & West)
- 2 x MTI Supreme 0.2db Single Output Universal LNB
- 1 x MTI Supreme 0.2db Quad Output Universal LNB
- Orbital SM1 U-Type Wall Bracket for Pole Mount Dish
- Eurostar 4x1 DiSEqC Switch
- Webro WF100 Cable
