PACE MSS 500 Problem?
Zalman
windows xp
turkey
Merhaba
Benim PACE MSS 500 analog arıza yaptı.Display ve receiver çalışmıyor.5 adet diyod var.GI 5402 nolu diyodun karşılıgı nedir acaba ?
Diger Diyod FES8FT 9644 Diyod.? Bunun yerine hangi diyod kullanılır.
GI 5402 Diyod = .......... Diyod ?
FES8FT 9644 = .......... Diyod ?
You must post in ENGLISH in this part of the forum.
Size post ingilizce bu kesimini fikir.
Zalman
windows xp
turkey
Merhaba Analoguesat
No İngilizce .
Pace MSS 500 receiver feeding failure and display.
GI 5402 Diyod = .....?..... Diyod = GI9632 Diyod ?
FES8FT 9644 = .....?..... Diyod
Merhaba Zalman :)
Use this site to translate your sentences. It should be close enough.
Bu site dönüşmemesi your hapis cezası verildi. Bu kadar yakın.
_http://translation.babylon.com/English/to-Turkish
Zalman
windows xp
turkey
.................edit
Zalman
windows xp
turkey
Merhaba
Pace MSS 500 analog receiver feeding failure and display.
UF5402 GI9640 diyod =....?...diyod
UF5402 GI9632 diyod =....?...diyod
SB350 GI9640 diyod =....?...diyod
FES8FT 9644 Diyod =.....?....diyod
SEC 632 SSP5N90 mosfet=.......?.....mosfet
SEC 639 TIP 31A =.......?......
2cvbloke
Near Pontop Pike, Co. Durham
I'm unsure of the fault, but this page may be of some use for Zalman:
_http://www.your-book.co.uk/mss500.htm
Zalman
windows xp
turkey
Merhaba 2cvbloke
Thank you. To examine link. UC3842 SMPS Controller entegre feeding tocreate problem Probably .
Zalman
windows xp
turkey
Merhaba
Zetex 749 ( display )
Zetex 450 ( display )
BR 30 (receiver ) what response transistör this.
Zalman
windows xp
turkey
Merhaba
To be repair absent scheme
Pace Mss 500 display (D5 )zener diyod .......?.....what
Zalman
windows xp
turkey
Hello
Pace MSS 500 is a long time edemedigim repair analog receiverimin only displayı is defective.
First on display diode D5 zenner burnt. That is defective.
On the fluorescent display I want to learn what it was D5 zenner diodun. Because my analogue satellite receiver on the D5 zenner deleted diodun not understand what oldugu. What should I use this instead diodun. ?
Pace MSS 500 will help you repair my edecegim device. I know the same alacagım.Sonrada failure D5 zenner diodu ways to repair the arayacagım.
D5 What you yazdıgını biliyormusunuz.Yada Pace MSS 500 display on zenner diodun have a circuit diagram?
What should I do?
NOTE: The device itself ettik.Çalışıyor.Başka repair a friend's satellite receiver, so another 500 Pace MSS displayını my device defective Pace MSS 500 are installed to the device display çalışıyor.Yani my device only plays defective displayı only a white line on the right appears.
Türkçe olarak soracak olursam;
Merhaba
Uzun zamandır tamir edemedigim Pace MSS 500 analog receiverimin, sadece displayı arızalıdır.
Öncelikle displayın üzerindeki D5 zenner diod yanmış. Yani arızalı.
Ben floresan displayın üzerindeki D5 zenner diodun ne oldugunu ögrenmek istiyorum. Çünkü benim analog uydu alıcısının üzerindeki D5 zenner diodun üzeri silinmiş ne oldugu anlaşılmıyor. Bu diodun yerine ne kullanmalıyım. ?
Yardımcı olursanız Pace MSS 500 cihazımı tamir edecegim. D5 zenner diodu bilirsem aynısını alacagım.Sonrada arızayı tamir etmenin yollarını arayacagım.
Siz D5 zenner diodun üzerinde ne yazdıgını biliyormusunuz.Yada Pace MSS 500 displayın devre şeması var mı ?
Ne yapmalıyım ?
NOT: Cihazın kendisini tamir ettik.Çalışıyor.Başka bir arkadaşın uydu alıcısını ,yani başka bir Pace MSS 500 cihazın displayını benim arızalı Pace MSS 500 cihaza takıyoruz display çalışıyor.Yani benim cihazın sadece displayı arızalı çalıştırınca sadece sag tarafta beyaz bir çizgi beliriyor.
