PCI motorized system fail to work...asistence req
glarus
Help! There is no signal..
skystar2 PCI tuner
moteck SG2100 motor
fortecstar uni LNB 0.4
ProgDVB says:
DVB Viewer:
DVB receiver:
There is power in the motor as I can operate it with the manual botton.
LNB isnt defective as I tried allready with Sharp 0.7db and nothing changes
glarus
I have the DiSEqC 1.2 plugin on ProgDVB but it doesnt operate the motor
WHAT TO DO!@!!!!!@!@!@!@!@!@!@!:eek: :confused :eek: ?:confused @
s*t*a*r*m*a*n
scotland
Go to settings/DiSEqC then click on property and choose the satellite you are on such as hotbird then click ok then ok again then go to "channel list" then channel scan. hope this helps. if you are on the sat and receiving a signal then you should see channels being detected. make sure lmb power is on.
damhy
Kent
che313 said:
I don't think ss2 support diseqc 1.2
Huh! It definately works on mine, which is a Rev 2.6C card. I thought for a while that it didnt work myself, and then I managed to get it to work with the drivers i mentioned above, you need to replace the file SkyNet.sys reboot, disable then re-enable the card in device manager, then use the plug-in. I have got it to work in ProgDVB and AltDVB. The standard AltDVB Diseqc option doesnt work properly, but if you go in the options for the plugin, you can control it there.
It definately works!
