relook 200s problem
hillway
db7000 90 CM triax moteck motor
well trying to install it !
NW
hi can anyone please help , i have set up a USA relook here in UK- put the img highland on. to PAL
everything works apart from when i have scanned via the search for channels
I cant get any pictures - I only have the sound working
can some 1 please assist. or offer any advise.
JADODAN
I HAVE MUTANTS 200S THAT IS CONECTED TO THE INTERNET.
UNITED KINGDOM
hi can someone advice me on how to install gbox on my mutant 200s. i accidently errased the initial installation. pls come to my rescue.
Likvid
Stockholm, Sweden
Here is a working gbox_cfg file for Relook 400s, try it out.
# gbox config file
# Task type
# 00 ** normal mode gbox mode (no season, use Multicam instead)
# 01 ** Season Emulation in a Irdeto allcam chid 0602 nonZ
# 10 ** Season Emulation in a Irdeto allcam chid 1702 nonZ
# 11 ** Season Emulation in a Irdeto allcam chid 1702 Z
# 12 ** Season Emulation in a Irdeto allcam chid 1722 Z
# 13 ** Season Emulation in a Irdeto allcam chid 1762 Z
# ** *1 Com port to use for season emulatiom (1 or 2)
# ** 0* Use CTS fr RST detectio
# ** 1* Use DCD fr RST detectio
# ** ** 9600 = Baudrate to be used (working only on dbox2)
W: { 00 00 } 9600
# gbox working mode
# 00 pure Emu
# 01 pure SoftCam (when card inside), Emu (when no card inside)
# 02 pure Net Client
# 03 Mixed mode !!!!! always use this !!!!!
G: { 03 }
# Display ECM messages on Konsole
# 00 don't show any ECM's
# 01 show only valid ECM's
# 02 show valid and bad ECM's with complete data display
C: { 01 }
# Display EMM messages on Konsole
# *0 don't show any EMM's
# *1 show only valid EMM's
# *2 show valid and bad EMM's with complete data display
# 1* Log any tier change on PW-Nagra-17xx cards into /var/keys/pwupdate.log
M: { 01 }
# AutoUpdate
# 00 is ignored (default)
# 01 enable AU
# 02 Auto AU !!!!! always use this !!!!!
A: { 02 }
# Key update
# 01 update only new keys, default setting
# 02 update all keys (used for valid PMK checking)
U: { 01 }
# Hash pids
# 00 hash all pids, DO NOT USE THIS OPTION, IT IS ONLY FOR TESTING STUFF
# 01 hash only pids with implemented algos and available keys !!!!! always use this !!!!!
H: { 01 }
# Key files folder
# 00 keyfiles in /var/keys
# 01 keyfiles in /var/tmp
T: { 00 }
#NDS overclock
#F: { 58 } 02 #6.30MHz
#F: { 58 } 03 #5.25MHz
# On Screen Display for the Multysystemcam on com1/com2
# 00 No OSD (default)
# 01 display Smartcard messages in Neutrino
# 02 display Smartcard messages in Neutrino new nhttpd format
# 03 display Smartcard messages in Enigma
# mypass (use user=root and pass=mypass for nhttpd)
O: { 00 } 192.168.1.3
# Logger and NET-mode UDP port Init
# 00 do not init UDP port
# 01 Init UDP port for IP, port, UDP
#F: { 01 } /dev/shm/pmt.tmp
# Trace/Debug
# xx yz ; xx=00 no konsole output
# xx yz ; xx=01 konsole output
# xx yz ; y=0 debug output (don't use)
# xx yz ; y=1 no debug output
# xx yz ; z=0 ouput to konsole
# xx yz ; z=1 output to /var/tmp/debug.txt
# xx yz ; z=2 Output to UDP (to capture with gboxt)
Z: { 01 12 } 192.168.1.2 8024
# *x ** ; x = device nummber to be used (0= default)
# D* ** ; force use of /proc/bus/gtx for cw write operations
(in the dbox2 the gbox writes directly the CW's, 00 is the
recommended mode ! No drivers are required) use D* ** ONLY if
you have Problems. 0* ** should be prefered !!!
# F* ** ; write CW's in both devices (used for PVR in STB04xxx devices)
# ** y* ; y=0001b (0x1*) use slot1 as Multicam (only on STB04xxx)
# ** y* ; y=0010b (0x2*) use slot2 as Multicam (only on STB04xxx)
# ** y* ; y=0011b (0x3*) use slot1 and slot2 as Multicams (only on STB04xxx)
# ** *z ; z=0001b (0x*1) use com1 as Multicam
# ** *z ; z=0010b (0x*2) use com2 as Multicam
# ** *z ; z=0011b (0x*3) use com1 and com2 as Multicams
# ** yz ; yz=00110011b (0x33) use slot1+slot2+com1+com2 as Multicams
# ** *z ; z=0100b (0x*4) invert CTS detection on com1
# ** *z ; z=1000b (0x*8) invert CTS detection on com2
# example: yz = 0x0A = 00001010 (use com2 with inverted CTS detection line)
V: { F0 30 }
