replacing systemsettings memory eprom or battery,in echostar lt 8700?
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
yesterday,after a heavey lighting,i disconect the power from my pc room,now my lt 8700,where i move,my egis rotor,over dvb 2000,and the comort,lost his memory,and shows please set east limit not on sat!
now,i should know,how i can synchroneized it again !
and the technical part,what type,of battery akku type ,or eprom inside,is needed to replace,that after interrupting the power,nothing happens again?
The battery in my Echostar SR8700 is the normal +3V cell (DL2430).
Likely to be the same in the LT8700.
I think they changed the EEPROM type in the LT, so might not be able to help there.
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
Hello!
i replace now ,the barttery.wirth the right type varta CR2430 3 V
but i recogneized,that it not solve the problem,the memory,is lost again and shows no sat,after power interrupt,would could be the other faults,that i could check when its not the battery?
