It will most probably be the free to air channels that don't require the card, the ones used by the UK Freesat service.
Do you subscribe to Sky? If the answer is yes, ring them and tell them you've been working in Australia or some other far flung country for the last two months and when you switched the box on it didn't work. Act dumb and make sure the card is in the original Sky Box. They will send a hit to the card over the air and it should re-activate. Do not tell them you are not in the UK
It may re-activate in the Dreambox, but i wouldn't risk it, best to do a re-activation in the original box. It should be ok from then on in the Dreambox once reactivated.
if you don't subscribe to Sky you could try asking Sky to send a hit to the card for the free to view channels if your the original card user but i don't know how sucessful you would be in pursuading them.
Ah, just seen your IP Address so what i've just written may be a little difficult. You may need to get somebody to ring from the UK for you
Can you receive the Sky Default transponder on the Skybox ( 11778V 27500 FEC 2/3) or have you had to set it to the one on the south beam?
The south beam transponder to use last time i looked was 12129V 27500 FEC 2/3. You will need to make sure the box is up and running before asking for the hit to be sent.
Nano
