"Sky" dish or circular dish?
pooksahib
Fixed Triax dish for Freesat.
Scotland
Hello. I'm in the North of Scotland and will soon be buying a dish and all that goes with it. I became a tad concerned when I read about some Quad LNBs not being designed for a minidish (although it could be that they're OK for the Zone 2 - big minidish - which I would need anyway. But I wasn't able to confirm that.)
Anyway, to the point. LNB compatibility aside, are there any advantages to having a 60cm circular dish rather than a Zone 2 sky dish?
While I'm here, which (if any) is better - solid or perforated?
Many thanks.
Its all about the same. I use a 60 cm circular ex analogue dish, but thats because I got if for free and I believe in recycling / reusing where possible.
satelliteman
Some ex analogue 60cm circular dishes are very well built.
Yes mine is - apart from the bolts on the lnb clamp rusting solid in the Scottish rain!
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Personally, I'd go for a zone 2 Sky dish, because they can be picked up more cheaply, and so can the LNBs, try ebay.
dvmedia
1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M
High Wycombe, Nr London, UK
Personally I've found better signal off solid 60cm circular dishes..
Although the differences are minor and anything said by anyone here is probably anecdotal at best...
Which satellite were you hoping to pick up..?
If it's only Sky, then the minidish would be fine - but if it's something like Astra 1/Hotbird I'd go for a non-Sky dish.
Robbo
Retired Mod
Gravesend,Kent,UK
Precisely, dish performance is not really an issue that needs worrying about too much for picking up sky or Freesat on 28E.
pooksahib
Scotland
Thanks all, I'm glad to hear that a Zone 2 is all I need. I had, for a while, been toying with the idea of a system to pick up other satellites but, from what I can gather, there's not much being broadcast on them that I'd actually want to watch. It might be different if I spoke a foreign language but I don't. A Freesat+ system for me, I think.
Any comments on my point about quad LNBs? Do you have to be careful in getting the right 'fit' for a Zone 2 dish?
Regards
Robbo
Retired Mod
Gravesend,Kent,UK
Yes, you should get one suitable for a Sky dish.
satelliteman
Require a quad LNb designed for a minidish.
