So long AFN
palermoj
PowerVu D9234 Decoder - AFN
Hiedelberg, Germany
Hi Turok,
I have both the new D 9835 and old D 9234 type decoders. I found that the old remote does is not totally compatible with the new D 9835. Some of the functions work such as Power and Channel button, but the menu and other buttons don't work. I also found that you can simply use a universal remote for turning on the decoder and simply use the menu button to set up the settings. The authorization (at least for AFN) you need to be an ID card holder (Military or Civilian) for the U.S. Military. There is a website at _https://pvconnect.net/unreg/auth1.php you can use to register the decoder, but like I said you may have problems registering since it will ask for an Army Post Office (APO) address. BTW, can you help me out with the Power Supply problem (clicking noise)? Joe
palermoj
Hiedelberg, Germany
Hi Turok,
Forgot to answer the last part of your question. Yes, the NATO Base is still here. Probably will remain, but the U.S. Army may be leaving in a couple of years. Still up in the air. Joe
palermoj
Hiedelberg, Germany
Hi Turok,
Hmm, looks like my first post did not work concerning the remotes. The remotes to the old type D 9234 and the new type decoder D 9835 are not totally compatiable. Some of the functions work but not all. You can also use a universal remote to operate your main functions and the menu button of the decoder to get to the menu. Joe
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
good idea,withe the universal remote,so i have to setup the decoder first,without remote,is a little bit difficult:)
with a universal remote,in the learning mode,it should be also posible,to copy,all the function into it,when some have the orginal one,we can clone the remote:)
what is the diffrence, of old and newer afn decoder?
can you confirm,that the reactivation,now must happen every 2 year online,instead of 5 years before?
palermoj
Hiedelberg, Germany
Hi Turok,
I can't really see a difference between the old and the new when it comes to functions, but the price is a big difference. The old decoder use to cost over $500.00 and the new one is only $279.00. Can't confirmed the registration period, but 2 yrs seems to be right, since I could only register my decoder for two years. This however, only applies to the military AFN decoder don't know about the normal registration. On the remote, once you have the decoder setup, you really only need the channel changer, volume control and the on and off buttons. O.k. now what about my question on the clicking sound from the power supply..any ideas? :) ciao Joe
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
Hello!
you find in this post,a shemtic of the power supply,how it looks it always the same part that its gone!
when you have connected,a afn decoder one time,then best you never replug the power,often in happen,that it gone,when you plug the power in..!
do you have a remote controll,for me to sale when you have currencly 10 afn decoders that are not working?
palermoj
Hiedelberg, Germany
I don't have remotes with my decoders, I just found the defective ones in the recycling center.. However, if you go to this website: _http://www.impaktproducts.com/Scientific-Atlanta-RM9234-Remote-Control-b-stk-p-16633.html
There is one availabel for $9.00. However, it may go fast!! Keep checking the website if it is already sold.
Concerning the power supply problem. Yes, I have already checked all the threads concerning the diagrams and the C9 Cap. Replacing the C9 cap does not work when the power supply has a clicking sound, it only works with the high pitch sound. In fact, I have already fixed three in the last two days. ;-) Joe
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
Sorry, there are no available shipping methods for your location.
the try & error prinzip realy works:)
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
Hello
!back again,in this topic,with some special questions!
can you confirm,that the older modell that i have 9234,is only sutable,for cband reception on 1 west?
someone told me this,but i cannot verify the source is it true or not?
he told in this modell it is not posible to swtich to kuband singals!
in cband on west,there is also one hd channels,in the package?
does it only work on the newer decoder?
thanks for your input!
the company from usa response in the meantime,the try to find a way sending the remote,currencly,waiting for a reply!
The D9234 does C and ku band. What's so special about the ku band TP's on 1W?
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
Afn Sports sending there in cband in mpeg 4 HD,so i wondering,how the old receiver can receive this signal,maybe it only works on the newer modell!?
The D9234 only has a DVB-S tuner.
djmoney
none
germany
i have a question i have a power light on and a signal light on to but cannot see the menu when i hit the menu button on the afn decoder do anybody know the problem but when i hook a different receiver up it works.
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
Hallo!
Guten Abend!
hast du es auch auf einem anderen Tv probiert?
einige Geräte,spezielle bei 100hz,haben Probleme,mit der Bildsynchronsiation,über das Chinchkabel,auf normalen 50 hz,funktioniert dann alles einwandfrei!
satexplorer
C2D
EU
Hi guys
Is there a shematic for the D9834 somewhere?
I've got a D9835, which is the almost the same as the D9834, but without RS232 and LAN.
Since it's the same pcb, it would be 'just' some missing parts. But what are they?
Or can someone please take a photo of that part of the pcb in the D9834?
Satexplorer
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
Hello!
the problem,what the afn decoder have is,after long analysis that the tuner is not very sensitive,and the voltage swiching,take to much power from the power supply!
i find out,that you can extend,the life time of the power supply ,when you use external voltage switching over another stb,to relieve the power supply itself!
the reason,that most nato base in war region have large sat dishes would be also the reason,why all technical components,of this receiver have very low quality ,this save alot of coasts in mass production!
i got now my remote controll with the type rm9234
this should be the right modell !
ralphmagno
naples italy
hello to all,
i wanted to make a new post but didn't know how to do so.
afn decoders hd.
they finaly arived at the exchange and they cost $370. but afn will not transmit in hd until 2012 or later.
afn kicked off 13 degree hot bird??
yes mediset italia is tring to get afn's 2 transponder and the satellite providers will not renew afn's contract
more money.
afn is also transmitting on 9 east on 11.766 vert. and more than likely will move there with another frequency and hd service.
afn will have to swap all the afn boxes out in the fiels as well.
there is no date its a mess for sure.
british forces service is moving as well.
they are moving from 7 east but there is no word to were they are moving.
well thats all the news i have for now
have a good day
ralph
have a good day
ralph
BFBS tested for a coupele of weeks on 10E last year so maybe thats a possibility
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
Hello!
lets hope that the picture quality,will be much higher on hd,then the current low quality picture:)
what is the exact type of the new ciso afn decoder?
there are many new modells out after ciso bought sintific atlanta,but only one is the right for afn!
I was right :-rofl2
BFBS are back on 10E 11222V 27500 3/4 NOT 2/3 as listed on flysat
