Starcom SR-X3500CUCI hex keys problem...
edem1970
Hi folks,
I am having problems upgrading my starcom sr-x3500cuci... I cannot find any program that will work (the files on satsw.com are for sr-x3500cuci Super and Silver sr-x3500 and EMUpgrade either wont accept them at all or wont start downloading).
I have been told that I can get around this by just entering the newest hex keys for the channels I want but I cant do that either. The procedure I was given for inserting the viaccess keys was;
1) Menu - ok
2) Installation - ok
3) STB - ok
4) Input code - ok
5) viaccess
6) enter code
My problem is that after I enter the installation screen there is nothing about STB so I go straight into the Input Code screen. Anotherr problem is that I cannot find anything to do with viaccess there either (just a key pad with numbers and letters.
I am getting desperate so any help at all would be greatly appreciated!
Elia from Cyprus!!!
