dp300969
- Aug 5, 2008
- Age
- 44
- DM800PVR
- Athens
Cheers to all,
I've the following issue that I desperately try to fix for a while now: I'm trying to stream from DM800 to PC using the web interface and vlc or Web-X-TV. I have the Nabilo blachole img running. Although it worked for a while in the beginning, it just stopped working. I've read more such reports of "suddenly stopped working" and I wonder if there is something wrong with the h/w.
Anyhow the log I get has as follows:
access_http error: error: HTTP/1.0 502 Bad Gateway
access_mms error: error: HTTP/1.0 502 Bad Gateway
main error: no suitable access module for `http://192.168.1.90:8001/1:0:1:1D53:2F44:13E:820000:0:0:0:'
main debug: adding playlist item `C:\DOCUME~1\DP\LOCALS~1\Temp\stream-32.m3u' ( C:\DOCUME~1\DP\LOCALS~1\Temp\stream-32.m3u )
main debug: creating new input thread
main debug: waiting for thread completion
main debug: thread 4128 (input) created at priority 1 (input/input.c:265)
main debug: drive letter C: found in source
main debug: `C:\DOCUME~1\DP\LOCALS~1\Temp\stream-32.m3u' gives access `' demux `' path `C:\DOCUME~1\DP\LOCALS~1\Temp\stream-32.m3u'
main debug: creating demux: access='' demux='' path='C:\DOCUME~1\DP\LOCALS~1\Temp\stream-32.m3u'
main debug: looking for access_demux module: 1 candidate
main debug: creating access '' path='C:\DOCUME~1\DP\LOCALS~1\Temp\stream-32.m3u'
main debug: looking for access2 module: 5 candidates
vcd debug: trying .cue file: C:\DOCUME~1\DP\LOCALS~1\Temp\stream-32.cue
vcd debug: could not find .cue file
access_file debug: opening file `C:\DOCUME~1\DP\LOCALS~1\Temp\stream-32.m3u'
main debug: using access2 module "access_file"
main debug: pre-buffering...
main debug: received first data for our buffer
main debug: looking for demux2 module: 45 candidates
playlist debug: found valid M3U playlist file
main debug: using demux2 module "playlist"
main debug: looking for a subtitle file in C:\DOCUME~1\DP\LOCALS~1\Temp\
main debug: `C:\DOCUME~1\DP\LOCALS~1\Temp\stream-32.m3u' successfully opened
playlist debug: starting playlist playback
main debug: adding playlist item `http://192.168.1.90:8001/1:0:1:13D:157C:13E:820000:0:0:0:' ( http://192.168.1.90:8001/1:0:1:13D:157C:13E:820000:0:0:0: )
main debug: EOF reached
main debug: closing input
main debug: removing module "playlist"
main debug: removing module "access_file"
main debug: thread times: real 0m0.125000s, kernel 0m0.015625s, user 0m0.000000s
main debug: thread 4128 joined (input/input.c:412)
main debug: `http://192.168.1.90:8001/1:0:1:13D:157C:13E:820000:0:0:0:' gives access `http' demux `' path `192.168.1.90:8001/1:0:1:13D:157C:13E:820000:0:0:0:'
main debug: creating demux: access='http' demux='' path='192.168.1.90:8001/1:0:1:13D:157C:13E:820000:0:0:0:'
main debug: looking for access_demux module: 0 candidates
main warning: no access_demux module matched "http"
main debug: creating access 'http' path='192.168.1.90:8001/1:0:1:13D:157C:13E:820000:0:0:0:'
main debug: looking for access2 module: 7 candidates
access_http debug: http: server='192.168.1.90' port=8001 file='/1:0:1:13D:157C:13E:820000:0:0:0:
main debug: net: connecting to 192.168.1.90 port 8001
main debug: connection in progress
access_http debug: protocol 'HTTP' answer code 502
access_http debug: switching to HTTP version 1.0
vcd debug: trying .cue file: 192.168.1.cue
access_file warning: 192.168.1.90:8001/1:0:1:13D:157C:13E:820000:0:0:0:: No such file or directory
cdda debug: trying .cue file: 192.168.1.cue
cdda debug: could not find .cue file
cdda warning: could not open 192.168.1.90:8001/1:0:1:13D:157C:13E:820000:0:0:0:
main warning: no access2 module matching "http" could be loaded
main error: no suitable access module for `http://192.168.1.90:8001/1:0:1:13D:157C:13E:820000:0:0:0:'
main debug: thread times: real 0m0.281250s, kernel 0m0.000000s, user 0m0.000000s
main: nothing to play
It seems like dreambox is asking from a service to get the stream but this service does not exist or is down. This service could be the streaming service of DB. Does anyone know how to find out if its running and what files does it need to run/config?
Does anyone have an idea cause I've looked all over the forums for a month now with no luck.
On the other hand, using web-x-tv I get a C++ error that its trying to illegally access library and does not work period. I have installed Stellar webif by a Nabilo team member in hopes to fix but no luck. Same situation...
Config is: 192.168.1.90 is the IP of my 800 dreambox, port 8001 is defined in stream.m3u.xml file and seems to be the default streaming port for the webif. I've tried to change to 80, 8080 but no luck.
Here is a list of other things I've eliminated:
- I play the channel I'm trying to watch
- Happens in both vlc DirectX output or default
- Ports are open, no networking issue
- I have tried it using an FTA channel in case it could not get stream from emu, while running Common interface, mgcamd, gbox in case it was an emu issue.
- Web if is working excellently other than that, I get remote, change channels see info, power options the works other than streaming that is what I need 'O'-red.
Thanks in advance, :-worship
Dee
Dee
