Super Power Jack
Archived-1
Persona non grata
uk
I am just going to have a play now C/J I had to go and pick the wife up from work,
Iv'e just swung her east and going to work back :)
Archived-1
Persona non grata
uk
57E locked, ignore what sats in picture, I will track back and see if I can get anything from 60E I have locked it before on my 1mtr but it was a long time ago and a feed.
Blimey, that dish is hitting the post almost. Is that at 57E?
Archived-1
Persona non grata
uk
I know C/J i need to set stops :-rofl2 when i know where to set them tomorrows job:)
no 6 big swings from post
Looks a proper "you can't bend it" job, Martin.
(Well, it will be when the stops are set!)
RimaNTSS
Some SAT-related hardware.
N-E from Riga
to prevent dish hitting pole, you perhaps need to make additional hook to the pole. For example:
Archived-1
Persona non grata
uk
Thanks rima, where the dish is in the first picture at the top of this page it probably pointing at 90e its easy to set stops without having to install an exhaust pipe:-rofl2 but thanks m8:)
RimaNTSS
N-E from Riga
Here is how I made mechanical adjustable stop. With it you can stay pointed directly to most-East (West) satellite and even without actuator.Screen_29 Jan. 10 18.25.jpg
RimaNTSS
N-E from Riga
Archived-1
Persona non grata
uk
That looks like a good job rima, on my old actuator I set stops in the actuator and I will with this new one, the dish will now run the full arc even though there is not much around the ends,
But I like to tinker like yourself :)
RimaNTSS
N-E from Riga
Of course, you should be careful with mechanical stop and not let actuator push antenna behind that.
When I set this stop then extend actuator to it's maximum and then fix it to mount.
RimaNTSS
N-E from Riga
But, TBH, actuator should be installed to antenna only when antenna is already tuned to all arc. I have special tool to quickly move antenna by hands. On that plank is also possible to make some pencil-marks to remember satellite positions.
Archived-1
Persona non grata
uk
Thanks m8, I will set them tomorrow and just track what I have got stored in tonight its dark here now and can not see were the dish is going thanks again rima :)
Archived-1
Persona non grata
uk
Here's mine rima:-rofl2
RimaNTSS
N-E from Riga
OK, if you bolt one side of wooden plank to movable part of antenna. make lots of holes in other side of plank (to be able to change position of antenna). Make mechanical stop and remove actuator. Than that probably will work :rolleyes:
RimaNTSS
N-E from Riga
Something like this: Maybe you need bigger plank and more holes. Attach it instead of actuator.
Archived-1
Persona non grata
uk
Thank you, I only fixed that on to fit the new actuator to keep my settings in place all I need to do now is swing the dish E and W just so it misses the pole and set stops.
RimaNTSS
N-E from Riga
I do not think you will need 2 stops. One is enough, the second one will be actuator itself when it is in shortest position.
Archived-1
Persona non grata
uk
There is two wheels in the actuator on is a west stop one is east stop you have to take a screw out and move them around to were you want them to stop east and west is very important one stop will be no good in my situation.
