Help Required Technisat SkyStar S2 PCI Problems
Woffelmannen
Humax Vaci-5350, Triax TD64, Triax Single Cable LNB TSC 001, Eutelsat 5W, 100cm dish, 4 lnb, Astra 19.2, Hotbird 13, Astra 4.8, Thor 0.8, 180cm Prime Focus, Astra 28.2
80cm dish, Samsung SMT-S5140, Astra 4A Viasat Family
Halland, Sweden
Hi! I recently bought an TechniSat SkyStar S2 PCI version from eBay. Now to the problem, when I tried to install it on Windows XP Service Pack 3 I got the error "The device cannot be started". Error code 10.
Does anyone know how to solve this issue?
The specs
Intel Pentium 4 3.00GHz
1 GB RAM
ASUS V9520/TD
Thanks in advance //Marcus
Skickat från min SM-G900F via Tapatalk
nelson_b
Contributor
The specs
1 GB RAM
ASUS V9520/TD
hi --
Which viewer have you installed ... e.g. - DVB viewer , --- Prog DVB -- DVB Dream - ?
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Are the drivers ok in device manager? As in no yellow triangles?
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Woffelmannen
Halland, Sweden
Thanks for all the quick answers and all the help. The problem got solved when I installed the 4.5.1 drivers.
//Marcus
