TPS AES updater for mgcamd
skywave
One 100cm dish with 3 Universal Quattro 0.6db LNBs at 28.2E, 19.2E, 13.0E..
One 85cm dish with 1 Universal Quattro 0.6db LNB at 0.9W..
4 - 4x1 DiSEqC switches..
DM8000HD, DM7020S, HUMAX VACI-5300, OPENTEL ODS 4000F
Luxembourg City
I begin to see why I have never been able to watch any of the TPS or Multi channels..
All the time I have - as 'instructed' in other fora - downloaded e.g. the s*tankeybundle.zip - unpacked it - and then ftp the tar.gz file to var/tmp on the DB..running gemini 3.0..
Then done a manual install from blue panel..
But after reading through this thread - I start realizing that the files in the kaybundle are not all where the are supposed to be..
E.g. the TPS Autoupdate file - I see that it should be in the plugin folder - but it is not..!?
I thought that the s*tan.tar.gz would distribute the files to the correct folders..? Or have a misunderstood something..? Should I really extract the tar.gz and distribute the 67 files myself - via DCC ftp - into the various folders..?
mhku
TM Nano ~ sg2100
Midlands
When you download a key file from a website unzip (or unrar) it to your pc.
It will create 2 folders: /keys and /scce
FTP the contents of /keys to var/keys and /scce to var/scce
I use the satan updater script (as I uploaded) to get my keys.
A file that was working last week may not work this week e.g. TPS key updater. The files that you need/ use will depend upon the emu that you use.
TPS_AES.txt will probably not be up to date in any key bundle so you may either need to create it from a program, use an updater or find one that has the keys for the next few days.
HTH
kobra1
jhkhhkhkhkh
hkhkhk
hello my friends ...
please tell me ... can I get the multivision keys autoupdated on my dreambox ???
please answere me ...
Can you receive TPS from your location hkhkhk ?
As far as I know there are no patches for the jhkhhkhkhkh receiver.
PS. Look at the post dates of this thread, it is a year old.
kobra1
jhkhhkhkhkh
hkhkhk
thanks my friend for post ...
so there is in the forum a card sharing or gbox exchange line to take the tps
because i need it too much
tankx all ...
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
tankx all ...
Kobra1 you are in the wrong place and asking the wrong questions, you will get no sharing or gbox help here.O-no
Sorry but you are wasting your time:-doh2
Maybe you should use google and look else where for what you are looking for:toke:
andrius
DM 7025
I am bit confused where to put tpsautoupdater.sh file. Regarding this thread it has to go to var/tuxbox/plugins but I don't have this folder. I am using germini 2.40 on 7025.
How can I install tpsautoupdater plugin on my unit?
PCD
DB Magician
andrius said:
AFAIK tpsautoupdater.sh does not work now.
You can autoupdate tps now using mgcamd1.25 (or evocamd). Put the latest dreambox keys (keys and scce) in, go to a France or M6 channel on 13e, wait until it clears, then to the channel you want.
If it does not work, delete /keys/tps.au and try again.
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
Just out of interest: Why do you have to go to France or M6 channel, would it not work with going to one of the Multivision 1-7 channels?
PCD
DB Magician
Don't know. Perhaps not necessary now, you can always try !
I don't move my dish to 13e nowadays, keeping at 30w, for which there a very good au at present for cabo and d+ - no need for twice daily update any more. I digress, sorry ! :)
Regards.
