Latest update: TPS works without interuption for the last few hours. What I did is this:
Install the following cams (I did it via blue button)
1) Evocam 2.11
2) Evocam config
3) Newcs_1.17
4) Newcs_config
5) Then ftp the latest keys, don't forget to CHMOD to 755!!
Note: I simply dumped a complete key bundle such as Satan keybundle (oywey.satandream.com, press forum button and download bundle) because I was not sure which keys are used. I suspect it is normal camd3.
6) Open up the camd_cfg file (is in var/keys) with a proper editor such as Ultraedit, and don't convert to DOS, and enter the following lines at the end:
wwwtps =
http://www.rubydesign.info/aes/linuxkeys.php
wwwtps_offset = 12
wwwtps_filter = %02x%02x%02x%02x%02x%02x%02x%02x%02x%02x%02x%02x%02x%02x%02x%02x
that should do the trick.
Additional notes:
1) The URL could be any other one you know of where they do keys.
In some cases this might be an option
fill URL yourself)
wwwtps =
http://xxxxxxxxxxxxx/xxx/xxxxxxx.php
wwwtps_offset = 0
wwwtps_filter = 0500:007C00:0000000000:00:%02x%02x%02x%02x%02x%02x%02x%02x:%02x%02x%02x%02x%02x%02x%02x%02x
Or like this:
wwwtps =
http://vhmarrouk-tech-sources.110mb.com/cood/linuxkeys.php
wwwtps_offset = 0
2) Also, make sure that there isn't another "wwwtps" line in the config file.
3) Make sure the AU entry in the config file looks like this (so it will autoupdate):
# AU
# 00 is ignored (default)
# 01 enable AU
# 02 AU Auto
A: { 02 }
4) If it don't work, try rebooting, and make sure all the keys and scce are CHMOD correctly.
Let me know if it works for you
