triax 1.1m dish or a gibertini 1m dish
parkiepie420
technomate tm-5402hd m3 /gibertini 1.25m sat dish 51e to 34w inverto black ultra single 0.2db lnb / titanium single output cband lnb
technomate tm-5402hd m3/triax 1.1m dish 53e to 24w inverto black ultra single 0.2 lnb
sheffield south yorkshire uk
at the minute ive got a triax 1.1m dish up as my secondary dish and been reading different posts on other forums stating that the gibertini 1m will out perform the triax 1.1m ???
has anyone taken the plunge and swopped the triax 1.1m dish and put up a gibertini 1m dish up
any ideas ??
Can't comment directly but if you mean the TD110 then it isn't a 1.1m dish. Its dimensions of 105cm x 100cm mean that it's actually a 1m dish.
Triax - TD110 std RAL 7035, singlepack - Wing nut
If the Gibertini is a true 1m dish then I would imagine the results would be pretty similar and choice of which one would come down to VFM, i.e. price, longevity and ease of adjustment (something a Triax fails on).
parkiepie420
hi paulr
thanks for the reply
yes its a td110 im just wondering if I will get any more signal out of the gibertini if anyone has gone from this dish to a gibertini ???
sonnetpete
wordpress.com
Normandy, France
An observation as I have only previously gone from a TD88 to a Gibertini 1M. I would think that because of the adjustment issues with the Triax, you would have a better chance of getting the Gibertini peaked to max, which in consequence may perform better than a Triax which is usually adjusted to a compromise when frustration ensues...
The differences will be marginal between the two in terms of performance. The Triax is a heavier dish, so will wear out a DiSEqC motor quicker than a Gibby. It also makes you wish that you were a mutant with 3 arms to handle the elevation adjustment, something that Gibby doesn't. Gibby every time for me....
sonnetpete
wordpress.com
Normandy, France
Rare photo of the head of design at Triax.....
Archived-1
Persona non grata
uk
You've got the bug Steve. save time an money and go straight for the 1.5 gib, its only a matter of time if you don't get one now :D
Journey
drx 890
Just a little input, from my own personal experiences having owned both dishes
I bought the Triax dish and had it mounted professionally with the intention of using just for 0.8w for certain channels when they were availble, it was used with an IBU (my lnb of choice always), i was left very underwhelmed by the performance of the dish
So, i went and bought the Gibtertini instead (having previously had a 1.25m which i was pleased with), the difference was like night and day for me, again using the IBU and in similar weather conditions there was a good 8% gain, which some may find unscientific and hard to believe but is the truth
On my satellite Journey i have bought many, many dishes, as some will know, i sold the Triax on privately a couple of weeks later as new at a loss
I still have the Gibertini now and use it for a different bird, but i would not swap it for anything of similar size
I hope these findings help and apologies that it is not the most scientific of feedback
parkiepie420
thanks for all your replies sonnetpete captain jack journey martin-f !!
im going to try the gibertini 1m dish and I will post results on both asap !!
parkiepie420
hi martin
sorry cant justify the price on the gib 1.5 at moment I would love one but then I would need a new motor etc to run it probably talking £400 for both maybe more ????
parkiepie420
unless a second hand comes up maybe ???????;)
If your TD110 is set up accurately (that's possibly a big if!) then I wouldn't bother with another 1m dish of any make. There just isn't any substantial advantage for the expenditure.
Your next move would be to a larger dish, maybe 1.2m if a 1.5m is too large.
parkiepie420
hi paulr
you have just put a big spanner in the works lol !!!
now that's got me thinking again !!!!:):)
archive10
Don't you like channel masters Steve ?.
I know I'm not Steve, but: Channel Masters always!
The rigidity of the plastic dish makes the CMs (and Prodelins and Laminas and Cahors etc) outstanding performers.
Only prob is that the CMs need a polar mount (or restored 1224), the others may mount on a motor, but needs to be kept it sheltered.
If you don't want to go the plastic way, I would say Gibby if for motor mounting.
But do consider the CM120 - there are always one or two on ebay...
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Sten is right, it is better to look for used CM 1.2m. There are couple for sale nearby me, already long time... No wonder nobody is buying them- owners ask too much. But I have seen such antennas sold for quiet reasonable price.
Archived-1
Persona non grata
uk
That's what I always said to myself st1, but after messing about with the precision I am seriously thinking of getting an new 2.4 Elite/precision.
I would like to see what performs best with my 1.5 v 1.5 gib. I will be able to test soon when Steve gets one :D
Pipedream
Sheffield
I have a 1.5 Irte sat in the garage, not far away from you
Archived-1
Persona non grata
uk
Is it for sale ?, ideal for Steve if its in his price range.
Pipedream
Sheffield
It's sat there doing nothing but there is no motor for it. Some one beat me to the 1224 I had my eye on
