uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
BlindFaith said:
TSReader-type receivers: create new channels manually with the corresponding ES_PIDs
As you said, I created a new channel with all Es-pids.All pids are the same as those in your pic.What's wrong in my setting?
Thanks.
BlindFaith
TBS 5925
..which plugin for descrambling?
...vPlug 2.4.4.0 with latest softcam.key,including BBC.What plugin you recommend?Thanks.
Zorch
TM 5402 HD CI+ Super+
TM 6800 HD Super+
TM 5400 SD CI+ USB
QualiTv QS 1080 IRCI MPEG-2 [4:2:2]
Fibo 1.20m x 1.35m Dual-Offset Gregorian Antenna [30.0°W > 57.0°E]
Inverto Black Pro
Aston DS 200 Interface
LG 42LD790 HDTV
NW Midlands, UK
Hi all,
I've just been on Intelsat 907 at 27.5°W
I Downloaded the channels from...
11.495V [44100] 9/10 DVB-S2 QPSK [Spot 1 Europe]
My Signal readings were...
Signal Strength 97%
Signal Quality 97%
The channels that downloaded were...
BBC One England
BBC One Scotland
BBC One N.Ireland
BBC One Wales
BBC Two England
BBC Three
BBC Four
BBC News
CBBC
CBeebies
BBC Parliment
301/CBBC Extra
BBC Alba
BBC Red Button
BBC HD
BBC One HD
ITV1 HD
Channel 4 HD
S4C HD
STV HD
I manually inserted all PID's into the channels...
I added the BISS key into the softcam...
I directed every channel (individually) to the same key in the softcam...
These are the channels I cleared...
BBC One England
BBC One Scotland
BBC One N.Ireland
BBC One Wales
BBC Two England
BBC Three
BBC Four
BBC News
CBBC
CBeebies
BBC Parliment
301/CBBC Extra
The HD channels require a different BISS key (as yet unknown)
Best Wishes,
Zorch
Same key for me Zorch.
ITV1HD -
Zorch
TM 6800 HD Super+
TM 5400 SD CI+ USB
Inverto Black Pro
LG 42LD790 HDTV
NW Midlands, UK
Hi Llew,
Strange... I couldn't get them to clear on my STB... just came up "No Audio/No Video" on the HD's...
Best Wishes,
Zorch
Zorch
TM 6800 HD Super+
TM 5400 SD CI+ USB
Inverto Black Pro
LG 42LD790 HDTV
NW Midlands, UK
Retired Mod
www.timo.me.uk
Just out of curiosity I nudged my Sky minidish from 30W to 27.5W to see if my TM6900 would lock on or even get a signal. I can't get any kind of lock, but when I tune in to 11.495V it crashes my sat input, menus get very slow and unresponsive and I can't tune in to anything on any satellite until I reboot. I can still tune in to Freeview channels though so it just seems to kill the satellite side of the receiver. Odd.
BlindFaith
TBS 5925
Zorch said:
Hi BlindFaith & Llew,
I am not using a PC Tuner card/PC Editor program (or whatever) to get these channels... just a HD STB...
Best Wishes,
Zorch
..you still have to edit the stream type.
jimbofz
fta 1.4mtr dish
uk and spain
Hi Blindfaith ,which edit s/w do you use to change stream type?
,ive looked im setedit,
and stb hd editor ,
after importing cha list cant see any way of changing stream from mpg2 to h262,
in menu "change t/p data "the network id is 0,and ts id is 0,
do they have to be changed ?
ive entered all sid ,pids ect and can now get good signal ,the constant cw data entered ok but still wont open
and stb hd editor ,
In Setedit, open channel data box for each HD channel and change Service Type to AVC HD TV.
jimbofz
fta 1.4mtr dish
uk and spain
Hi Llew,just tried that ,changed the hd chans to AVC HD TV,
sadly still wont open
satro
Dbox1,Manhattan Plaza,Humax5400
south
Hi, Could this Sat be received in Cyprus?
BlindFaith
TBS 5925
..I'm using a different plugin but as Llew proved vplug should be ok.
Installing the plugin and getting the correct key is imho not enough. You have to assign the DCW for each channel indivudally! Dunno if vplug requires the key as 48bit or 64bit. Looking at Llew's screen shot tells me that 48 works ok ;)
ps.
@satesco, you should reset the error counters in TSReader before making a screen shot. Otherwise it looks that you receive a broken stream that can't be descrambled anyway.
jimbofz
fta 1.4mtr dish
uk and spain
how do you assign the DCW for each channel?
can it be done in setedit?
BlindFaith
TBS 5925
no, in the embedded emu (emu-firmware). Even then there's no guarantee that it will work. I've tried the same without success in a vantage stb :(
remlap
Wales
Does S4C clear just wondering?
Your suggestions have been useful now only for dvbs2 player.I'll try later on with TSReader.
Actually here what I did:I took V-pids,A-pids,PMT-pids for each channel from this list and I entered manually,then I assigned each channel DCW for each channel.
On this occasion I found the explanation for Data icons in the player{see #70};for each channel must input video pid.
BBC One England -SID:4164 PID:101/102 English,106 English).
BBC One Scotland-SID:4220 PID:4101/4102 English,4106 English).
BBC One Northern Ireland-SID:4221 PID:5101/5102 English,5106 English).
BBC One Wales-SID:4222 PID:3101/3102 English,3106 English).
BBC Two England-SID:4287 PID:201/202 English,206 English).
BBC Three-SID:4288 PID:301/302 English,306 English).
BBC News-SID:4352 PID:501/502 English).
BBC Four-SID:4544 PID:401/402 English,406 English).
CBBC-SID:4608 PID:301/302 English,306 English).
CBeebies-SID:4672 PID:401/402 English,406 English).
BBC Parliament-SID:4736 PID:601/602 English).
BBC HD-SID:17472 PID:6101[MPEG-4] /6102 English,6106 English).
BBC One HD-SID:17540 PID:6601[MPEG-4] /6602 English,6606 English).
ITV 1 Central West HD-SID:17608 PID:6201[MPEG-4] /6202 English,6206 English).
Channel 4 HD-SID:17664 PID:6301[MPEG-4] /6302 English,6306 English).
S4C HD-SID:17792 PID:6401[MPEG-4] /6402 Welsh,6403 English,6406 Welsh).
STV HD-SID:17856 PID:6501[MPEG-4] /6502 English,6506 English).
Voila,BBC Four channel:
Good news satesco. Yes, every channel must be assigned their respective parameters.
