Unable to mount CIFS share - Not a directory
picc2001
DM7020
XIRILANKA
meltyblood said:
Try entering this:
echo 0 > /proc/fs/cifs/LinuxExtensionsEnabled
then mount with CIFS. It worked on my OpenWrt router.
Can you show me the mount command you are using?
mount ....
are you experiencing problems (frezees... instability..)?
Regards,
Picc2001
meltyblood
Hell in a basket, Europe under Blair's fingernails
Fourletters
I use a set of scripts I've written to mount CIFS. The command generated is essentially:
'mount.cifs //PC_IP_ADDRESS/SHARED_FOLDER /mnt/cifs/MOUNTDIR -o user=USERNAME,pass=PASSWORD'. Remove USERNAME and/or PASSWORD if you don't happen to have one.
billnot
Growing Old Disgracefully
Famaval 3,1, IP9000HD plus other FTA and Linux boxes - Astra 1&2, Hotbird, Hispasat
Benitachell, Alicante, Spain
meltyblood
Fourletters
That's right, although there is a mount.cifs tool that allows you to use my command.
