Understanding Passion settings- Please help
thomas
novice; fortecstar
barnoldswick Lanc's
I recently purchased a h/d pasion sat rec/box,but being a novice i am struggling to understand the four digit imput No's and how to lock them in to fav list and how do these No's re-late to tv listings? can anyone help? thanks. Tom
All named channels have corresponding four-figure numbers. Are you saying that the channel names in your list are numbers instead of names?
thomas
novice; fortecstar
barnoldswick Lanc's
Hi liew, thanks vm for ure reply.when i press white for fav list the ch No's come up thus:- 0975 itv yorks - 0942 bbc west, 0984 bbc4- 0985 bbc3 etc, how do i lock these into the fav list? the orange butn brings up the last 5 ch's watched. The t/v listings in the Sun t/v mag gives different ch No's, i.e. for bbc4=sky116,virgin107 and bbc3 as sky115 and virgin106, so i presume that each media company has its own set of No's built into their own equipment. I am only on free to air sat, and as you can see, i'm a bit new at this system, but very pleased with the picture quality,- if I could only get it organised right. so I would be glad to hear from you again. thanks Tommy.
Forget the channel numbers published in the newspaper. These are the EPG channels for the Sky boxes.
To add a channel to a Favourite list -
Press Menu
Right click to Channel Edit
Input Password as 0000
Select which channels you need to make your favourites
Press Mosaic button on your remote. A * appears beside your selection(s)
Press White button, then OK to add to the Fav list
Press OK and save the result.To view a Favourite, press the White button twice.
I'm assuming you haven't a user manual, as it describes the procedure there.
thomas
novice; fortecstar
barnoldswick Lanc's
To Llew = thanks very very much for those instructions Llew , i will put them into operation tomorrow - and yes, i do have a manuel with the box,and i have read that section about ten times over but i never realised that i had to imput the 0000 number. so its making sense now, so thanks v.m. again, and for being so quick, cheersTom mirfield
Retronana
None
United Kingdom
Whilst we are on the subject of "How do you do that"
Is it possible to create a new Fav list, I see you can edit the title and you then remove all the channels in that Fav list and then replace them.
I want to create a new HD Fav list (I know there are only three...but you got to start somewhere !)
Can it be done ?
Use the Setedit program to change one of the seven favourite lists to your choice of name, then you can add channels to that list in Setedit by copying/pasting to the Favourite list box.
thomas
novice; fortecstar
barnoldswick Lanc's
Llew, followed your instructions and "bingo" so i am well pleased. I read your advice also to Retronana, which will also come in handy (ive printed them off) so thanks again very much. all the best Tom Mir...
Good to hear that Tom. A belated welcome to the forum :)
LLew
