Have mice or other critters in hidden areas???
Use an old farmers trick, if the area is not accessible to normal human traffic or is in a location that can't be reached by children, (under something, in an attic space or behind a cabinet) then a good liberal sprinkling of red cyan pepper will stop the chewing.
If you are going to do this then go to a dollar store and get the cheapest stuff you can get, and use a dust mask as this stuff will tear you up.
I sprinkle it around gofer, rabbit and ground squirrel holes (active ones) they never come back. (don't try this if you have dogs or cats)
A fun way to trap squirrels is with a barrel trap, a metal 5 to 35 gallon garbage can or other large metal barrel is used (metal is used as they will chew through a plastic one) along with a metal rod.
Two holes are drilled right below the top rime of the can, then a 2 liter plastic coke bottle with a hole at the bottom is used, the conduit is fed through the hole in the top of the can with the coke bottle at the center, make sure it rotates freely.
A liberal amount of peanut butter is spread on the center part of the coke bottle.
A small ramp up to the top of the garbage can is used to help the little critters out.
Here is a nice video to watch.
https://youtu.be/yC1XNDyxE4c
If you don't want the little SOB's around then put some soapy water in the bottom of the can. (deep enough so they can't stand up, the soap is added so they cant float)
