Help Required weird problem with Prof7301
khafan11
prof7301
iran
hi
i have prof 7301 i just find weird problem i cant receive data freqs !! but i receive DVB-S2 and HD channel fine !!
i change LNB , but it's same problem
Mickha
North West
Can you please tell us what frequencies, and satellites, you're having trouble with.
khafan11
prof7301
iran
Express-AM22 @ 53° East
12708 V 9000 5/6
12695 H 3333 3/4
DVB-S2/8PSK
this and
Intelsat 901 @ 18° West
11585 V
DVB-S2/QPSK11104 3/4
Where are you located - the "East" in your profile isnt very helpful. The country will do if its not too big, a nearby biggish city if its a large country
khafan11
prof7301
iran
i live in iran if you want to say iran have'nt beam for this two satellites You're wrong i recive all frequencies on this two satellites just dont receive data
smoggy07
Can your receiver decode the data signals? Most of the time the data feeds will be internet data and won't be receivable on standard receivers
Look for a program called SkyGrabber and download it, install it on the PC that has the PCI card installed and let it run on one of the data freqs, that should start to sniff the data packets/files (if it still works and they haven't changed the data format)
If you dont have the correct lnb for the data TPs I.E. Ka band or Ku band then you won't get anything
khafan11
prof7301
iran
this frequencies for Internet by Satellite , in past i receive fine without any problem ! right now my friend have singal
Iran is fine - we know you have to be careful what you say from there.
The Prof 7301 seems to be a standard PCI computer card
You certainly seem to be under the beam for those 3 frequencies. Do you get other data streams? If so those 3 may just be offline for some reason. Or the transmission parameters could have changed. Few hobbyists log data streams as they dont have the equipment, so changes can take a while to show up on the frequency sites..
In that case triple check you have all the parameters correct - its easy to put H instead of V
