Which satellite receivers have built in spectrum analyzer?
BombedOne
Republic of Georgia
I've researched a lot of this subject, in attempts to find cheap receiver with built in spectrum analyzer, but not so much results. So far, results are as follows:
1. Relook 400
2. Tripple Dragon
3. Clarketech HD5000C+, DR HD F16, Technomate TM 6900 Super +
4. Openbox/trimax/etc clones, mostly marked as "SF-30"
anyone knows any models I've missing?
BombedOne
Republic of Georgia
Are they still manufactured/available new?
chillzoutguy
sky
Afraid not as they were manufactured in the late 90s. You can try ebay
nelson_b
Contributor
rolfw;852501 PS. Emitor do a cheap unit called the Spectralook said:
http://www.satellites.co.uk/satellite/meeting-place/13048-special-member-offer.html[/url]
yes -- a very usefull tool - had one for many years now --
not sure that they still make them anymore ?
cant see them listed on their website now --
regards nelson.b
BombedOne
Republic of Georgia
Thanks for offer, but this unit seems to be too simple - no zooming, no tp locking....
BoSSpak
Orbitron MicroMesh 3.6m dish with chaparral polarotor,SMW X-LINE TYPE E LNB.Nokia Dbox1, DM500s.Drake ESR 2000XT + Echostar LT8700
East of England
Nokia 9200/9500/9600 with DVB2000
The box has to be connected to a pc either via rs232 or scsi port. You will need a utility program called DvbEdit, this has the function for the spectrum analyzer. DVBEdit 5.0 build 61 was the last release.
Scanner options:
Much improved scanner. The scanner now generates a calibration scan the first time a particular LNB configuration is used. When this scan is operating, you need to remove all signals from the LNB by simply taping a piece of cardboard in front of the LNB. DVBEdit then uses this calibration scan so that the scanner charts aren't so dependent on the output signal from your LNB and on the sensitivity of the Nokia tuner.
Screen shot:
BombedOne
Republic of Georgia
Thanks, but how fast is screen refresh? is it usable for dish adjustment/installation purposes?
BoSSpak
East of England
Its been a while since i last used it m8 ( over 6 years ago), sorry can't recall if the screen refresh rate was fast. Don't have the same setup to try and test for you. Only have a laptop with no serial port :mad: and dbox1 is in the loft collecting dust.
wideman
2,1m Prime focus dish, Dbox1, Dbox2, HTPC with TT S2-3200
Moscow, Russia
ernest1
DVB receiver: Satr2 Dish antenna
iran
Hi..
how can I receive signal from Intelsat???
audi-tek
TM6900 HD COMBO,1.2M MOTORIZED, DARKGOLD LNB
WINDOWS XP
Cobh,CO.CORK.EIRE
1. Relook 400
2. Tripple Dragon
Are you sure that the ClarkeTech HD 500 Combo Plus, has a spectrum analyzer, as I cant find any mention of it in any spec for the receiver, when I google it.
Cheers:confused
