Just Sharing This Project Clover
what is even this going to be used for?
Experimentation of course :D
We are a technical forum, and the members here have a great track record of coming up with ingenious bits & pieces, or repurposing spare kit for novel purposes.
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
Irradiating Sky "Engineers"?
But seriously, it's an experimental rig to create large dish performance using an array of smaller dishes. Fascinating stuff.
or you could just buy a bigger dish lol
Too mainstream.
Trust
Nijmegen Netherlands
Trust
Yes, where's the fun in going the easy route?
satkijker
See Signature.
Mill Netherlands
Why do easy as it possibly can be difficult.
The impossible does Trust1 immediately, miracles do Trust1 little longer.
.... It's in your blood. If you are a satellite enthusiast, with engineering / fabrication / brainstorming etc capabilities and urges, then it just comes natural to have a go at that "idea" that appeared in your mind .... you can't help it. Yeah, there's a 90% chance it will never fly but you get so much enjoyment out of the whole process that it really does not matter. Nice one Trust1.
Wow! the only issue I can see is the dishes will have to in Phase..otherwise it might cause all sorts of unwanted nasties, a bit like some TV aerial arrangements, but I could be talkin' out of my backside...
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Yep ..sure I mentioned the phase issue ..
But IF he does manage to get all in phase ...it will work..
So ..mad I am indeed ..but no more mad than it's creator I 'trust' ?
Trust
Yesterday I finished some changes , made a 25 mm diameter bar through the centre of the cross fitting in a gearbox .
The gearbox is on top of the modded poleclamp and can be turned by a hand to turn each dish on top .
Also had to make a new elevation fine adjuster .
Now the quattro-feed is also connected by a M10 threaded rod to the top of the 25 mm bar .
satmania
Tiger receiver. FUJI lnb. skystar usb hd pc card
Beghazi Barqa Cyrenaica
i think if you use small prime focus dish as reflector will be better, because waveguide need straight feedhorn to work perfect way.
in your system 4 holes of feedhorn have to be face to needle of lnb sure it's difficult... but not impossible
rgds
Trust
rgds
Ever looked into a corotor ? the ku lnb is also around the corner .
satmania
there's difference between ku band and cband waveguide.
what i know when is feedhorn very long or there is contortion the signal becomes weak, however you have attempt
and you would tell us about result.
Trust
I am aware about the difference between C and Ku band wave guide .
But since a Ku lnb attached to a corotor is doing his job , I think there is a chance my quattro feed will work .
satmania
sure it'll works but Does will work a perfect way? i am eager for your experiment.
corotor system
mosllam
240 cm local motorized dish and 2 fixd 180 cm local dish with multi lnb VU+ DUO 2 yuner in use
Egypt- Cairo
just to keep us occupied !
i hope you get the best result
i did not try ( array ) before but some others try it with bad result
i Believe its ( phase ... ) problem as expert says
so clearly its not about building a bigger dish
but is it necessary to have the 4 dishes in one mount
or you did it to use just one lnb + 4 feed because of the ( phase angle ) problem
I tried to do a some thing similar two years ago - but was for building a bigger PF dish from 3 offset 1m dish
i started with two offset - one lnb but could not get any improvement in signal
Trust
Monday when I'm back home from vacation , the unit is gonna setup again (when the weather is fine )
digihoe
Too many boxes. One motorized dish.
Sweden
Happy to see someone crazy enough to make this setup, I had the same idea some years ago (Anyone tried to make BIG dish at home?), your lnb setup is quite interesting, if you get timing issues, please consider a reflector or a coneantenna/feedhorn.
Best regards and best of luck!
