davemurgtroyd
As per title - wanted remote control for Grundig MDC 65 CD Minidisc recorder. Not fussy whether original or replacement.I've exhausted Google, Yahoo and most ebays.
Thanks but no joy there
I too have found Logitech Harmany remotes to be the best in terms of the pre-programmed functionality, I have had to teach my Harmony Touch very, very little from any genuine remote. Could be you best bet, although these are not cheap..Well, a universal remote is your best choice at the moment.
Good luck
I agree.I too have found Logitech Harmany remotes to be the best in terms of the pre-programmed functionality, I have had to teach my Harmony Touch very, very little from any genuine remote. Could be you best bet, although these are not cheap..
Link shows that it also requires Harmony hub??I agree.
This link shows that all harmony products support the Grundig MDC-65
I bet it is cheaper to buy it than an original remote that is not available anywhere.
Device Compatibility
When I type the Grundig model, I get
Grundig MDC-65
All Harmony products can control this device
This device is supported.
In addition, you can use the Logitec 650 to control 7 more devices.
I don't know what that means.Link shows that it also requires Harmony hub??
