Resurrecting a Legacy X86 PC..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I got IE3(?) to access 'tinternet on my Toshiba Libretto last year, but it seemed to not understand how to display the google logo at the time... :-lol
Yep that's exactly what I got earlier buddy ..
and why I went for the upgrade to IE5.5(sp2)
Perhaps you too could do the same ?
I'll pop the zip in my dropbox for you if you want to try ..?
but of course it does depend a lot on the version of Win95 you are running ..
The one I'm running is 4.00.950 (B )
2cvbloke
Near Pontop Pike, Co. Durham
I took that picture last May, not quite sure where I put the Libretto after my last tidyup, it's a small subnotebook that is easy to hide, intentionally or otherwise!! :-doh
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Well if you dig it out and want to try ..let me know so I can upload to dropbox..
not bothered about making the key public ..
it's freely available on the net..
lol
2cvbloke
I think I downloaded IE5.5 from somwhere for it, I just never got round to transferring it over, the screen has issues where the LCD panel will lose connection from the circuitry inside the screen assembly, a terminal fault for most, so, I rarely use it, it's just one of them things I had to have as I repaired a few of them (and the later 100CT version) in my time at the computer shop... :)
I put win95 onto a computer with the minimum specs of ram once (4meg!)
It would start up - eventually. But it was useless - every time you tried to do anything it crashed immediately :D
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Very impressed speed wise with Chameleon as a DOS bare bones ..
Done my first WAC700 drive ..
Took around 3 hours ..to do what I used to leave running overnight..
rgds
2cvbloke
Windows95 was the best and fastest OS microsoft ever made, at crashing... :-rofl2
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
.and there's me thinking that accolade went to Vista..
2cvbloke
Nah, Vista just makes you suffer before it crashes, different category entirely... :-rofl2
ME is surely the glass-jaw contender.
I could never take to any OS that insisted that it was all about ME.
2cvbloke
battenfan
1.2m pf
60N 18E
I have a 3c905 card and I'm pretty sure that drivers for it are included in xp.
I might have drivers for 95 somewhere, probably on some disconnected drive, tell me if you want me to look for them.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Nothing really new to report as yet ..other than I fried The primary IDE port master ..
Stupid stupid ...stupid ..
But the secondary Master ,Secondary slave ..and Primary Slave are still good ..so Can still boot all the OS ok
I'll keep watching fleabay in case a used Jetway suitable mobo turns up..
In the meantime ..
I can now report pullout working OS for win 3.1
Win95 B ..
I even got 95 to install a universal serial bus root hub driver ..
but still cant recognise a usb stick ..
Still working on it ..
But at least I can access google on it with reasonable display ..
IE 5.5
32 bit truecolour 1152 x 864 display..
..and I have network access with the 3com 905 ISA card..
Win98SE
2000 (sp4)
and XP home and Pro ..
The latter 3 OS went in no problems ..but then ..better support for plug n play makes a helluva lot of difference..
So ..
why am I doing this ..
same answer as ..
why climb a mountain..
cos its there ..and cos I can..
Just spotted this on fleabay in the states ..
Ultimate Windows 95 DOS Gaming Computer PCI ISA Leisure Suit Larry Sierra Gaming | eBay
or this one..
Windows 98SE Compaq Evo D530Desktop PC - for Gaming, Legacy pograms, Embroidery | eBay
Which only goes to show ..there are still Retro PC enthusiasts out there ..
And those do a fraction of what Chameleon can do ..
:D
2cvbloke
Ooooooooor:
http://www.ebay.co.uk/itm/331361885957
PCI IDE controller, adding an extra 4x IDE drives to the system, making up for the loss of one... :D
(As an aside, I use a Maxtor-branded PCI IDE controller in my Olivetti Pentium75 desktop to be able to let it use a 20GB seagate condom drive (you know the ones, with the black rubber wrapping cos they're so damned noisy!!), not a RAID controller, just basic IDE...)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Ooooooooor:
A good idea buddy ..
My main worry would be early windows support ..
Not supplied with drivers ..so may not even be recognised by 98se 95 and even more doubtful 3.1
..so may be of use in XP or 2000 ...as a slave unit ..but doubtful it would provide bootable option as a replacement for blown IDE master (0)
..have you ever used one ?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Ooooooooor:
Took a chance and ordered one ...
It will always fit in my main PC (ASUS Z97 mobo )which has no IDE..
2cvbloke
Not one of those, but my Maxtor one that I mentioned works fine with 98se, it just acts as an IDE interface and just works, don't know about older versions of Windows, but it should work, if that one has RAID then that could cause an issue with needing drivers, but, we shall see... :)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So ..after much reading it appears USB on windows 95 IS possible but it has to be done on a clean new installation very early in the build ..
Well ..
I have some spare IDE drives so why not give it a go ..
Build 2 is now in process..
lol
XUSBSUPP - eXtended USB Supplement for Windows 95 OSR2
