Advice Needed Building a server for Tvheadend.....
Archive-8
Over the last couple of days I have been building a machine from parts I have around here.
Got the machine built, Ubuntu installed, went to plugin in my Sky Star 2 HD pci-e card and found it’s not Linux compatible.
So now I need to find a Linux compatible sat card, I want twin dvb-s2 and twin dvb-t2 inputs.
I don’t mind if I need 2 cards to do this as I have 2 pci-e slots on the mother board.
I have been looking at the tbs 6522 as that has twin sat and Freeview, anyone had experience with these cards?
I can only get T/T2 working with the TBS6522 in Linux Chris (except using DVB apps in a command line)
Maybe worth my trying TV Headend, let us know how you make out with it :)
Archive-8
What Linux version are you using please, as Ubuntu just seems to throw up hurdles every step of the way.
Might have to try another os.
I seem to be struggling to get it to scan in a network.
Did you know there is a third party driver also available.
Home · tbsdtv/linux_media Wiki · GitHub
Mint Linux.
That driver is the one I used.
Try something like w_scan in terminal. At least it shows me that channels will scan in using the S/S2 adaptor 0 frontend 1 of the 6522. Example with my dish on 28.2 -
david@david-MS-7850 ~ $ w_scan -fs -s S28E2 - o 7
w_scan version 20141122 (compiled for DVB API 5.10)
using settings for 28.2 east Astra 2A/B/C/D + EuroBird 1 28.5
scan type SATELLITE, channellist 61
output format vdr-2.0
WARNING: could not guess your codepage. Falling back to 'UTF-8'
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
    /dev/dvb/adapter0/frontend0 -> "TurboSight TBS 6522 DVB-S/S2/DVB-T/T2/C " doesnt support SATELLITE -> SEARCH NEXT ONE.
    /dev/dvb/adapter0/frontend1 -> SATELLITE "Silicon Labs Si2183": very good :-))
Using SATELLITE frontend (adapter /dev/dvb/adapter0/frontend1)
-_-_-_-_ Getting frontend capabilities-_-_-_-_
Using DVB API 5.10
frontend 'Silicon Labs Si2183' supports
INVERSION_AUTO
DVB-S
DVB-S2
FREQ (0.85GHz ... 2.30GHz)
SRATE (1.000MSym/s ... 45.000MSym/s)
using LNB "UNIVERSAL"
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
trying 'S  f = 10714 kHz H SR = 22000  5/6 0,35  QPSK  (0:0:0)'
(time: 00:00.524)
trying 'S  f = 10729 kHz V SR = 22000  5/6 0,35  QPSK  (0:0:0)'
(time: 00:02.980)
trying 'S  f = 10744 kHz H SR = 22000  5/6 0,35  QPSK  (0:0:0)'
(time: 00:05.440)
trying 'S  f = 10758 kHz V SR = 22000  5/6 0,35  QPSK  (0:0:0)'
(time: 00:07.900)
trying 'S  f = 10773 kHz H SR = 22000  5/6 0,35  QPSK  (0:0:0)'
(time: 00:10.360)
trying 'S  f = 10788 kHz V SR = 22000  5/6 0,35  QPSK  (0:0:0)'
(time: 00:12.820)
trying 'S  f = 10803 kHz H SR = 22000  5/6 0,35  QPSK  (0:0:0)'
(time: 00:15.280)
trying 'S  f = 10818 kHz V SR = 22000  5/6 0,35  QPSK  (0:0:0)'
(time: 00:17.740)
trying 'S  f = 10832 kHz H SR = 22000  5/6 0,35  QPSK  (0:0:0)'
(time: 00:20.200)
trying 'S2 f = 10847 kHz V SR = 23000  2/3 0,25  8PSK  (0:0:0)'
(time: 00:22.660)
trying 'S  f = 10862 kHz H SR = 22000  5/6 0,35  QPSK  (0:0:0)'
(time: 00:25.124)
trying 'S  f = 10876 kHz V SR = 22000  5/6 0,35  QPSK  (0:0:0)'
(time: 00:27.584)
Tut tut. I had the wrong cable connected to the LNB in my earlier scan above - going to the TBS6983 instead of the 6522, hence no TPs found.
Better now, all channels locked and identified.
Still only T/T2 channels found with the updatedvb program, will need to check with the guys at Ricks, they've been very helpful in the past.
Archive-8
Put mint on this morning and to be honest I am still struggling with the driver install. I get to the point of make and it keeps failing.
Glad you got it sorted re swapping the cable to the right card. I think I would need to try and mark the face plates so I could identify the correct card.
Archive-8
Switched to the tbs drivers and pleased to report the card is now installed correctly :)
Next stage, tuning the channels in.....
Excellent. Yes, not much room to fiddle around screwing in the plugs. I've wired up the terminals to flying leads marked with their inputs :rolleyes:
Enjoy the card, a decent match to the TBS6983.
Archive-8
Now got the fta 4K channels.
E8D377EA-853E-4D1F-800E-9B5DC8636DB4.jpeg 8368AAD8-5F0C-48AA-9829-1640DB1CF164.jpeg 878BFA7F-FF37-48F6-9E85-A136B1693DE4.jpeg 3F3EC553-F0E6-438F-A182-46E8ABC038D1.jpeg
Archive-8
Installed plex to run along side tvheadend :D
All I had to do was point to the recordings folder, all finished now.
So far so good.
Archive-8
@Llew or @Lazarus can I use samba and ssh with mint?
As I want to be able to mount the “server” hdd to one of my windows 10 machines.
So I can transfer files between them.
Thanks.:)
