Remote control repair tip.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Some buttons weren't working so I got some conductive paint from China. The problem was it didn't dry fully and would come off on the circuit board.
Solved the problem by putting drops of the paint on a piece of printer paper where it did dry then cutting out small circles and super glueing to the silicone buttons.
I use a - carbon/HB - pencil, but then I'm cheap like that
2cvbloke
Near Pontop Pike, Co. Durham
Try cleaning them with STP Brake Cleaner, it's usually grease and oils from fingers that soaks into the rubber that causes a lack of conductivity, I've done this with a few remotes that were "beyond salvage" and, er, salvaged them... :D
(the brake cleaner's also useful for just just general degreasing too, well worth having around the house!)
For brake cleaner (doesn't have to be STP!), try your local motor factor - such as GSF or ECP.
I just use common or garden cream cleaner.
dmaavrigdo
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Mine had definitely had the coating worn off I can still see it on the buttons that are rarely used. Research has informed me that part of the problem is caused by insufficiently baked silicone that continues to leach silicone oil and reduces adhesion.
Have you tried the pencil technique ?
dmaavrigdo
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
2cvbloke
So, you've worked it out, then? :-buttkick
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
I've glued some little dots of aluminium foil on the contact side of malfunctioning buttons.
Works also. :)
greetz,
A33
Retired human
Repaired my Samsung remote with some HB pencil this morning - can power it on/off now without swearing.
Never seen a Tourettes operated remote before, though B3ta had a keyboard design years ago.
