Going motorised, what to buy? - Feed hunting.
TJExcalibur
Out of this world.
Southern England
I checked with WOS forums and seems WOS are not selling with DVB-S2X yet, so looks like this box is off the list.
Look in Google for DVB-S2X tuner. lots of info there.
Tururu
Assembled with recycled parts
Recycled as the owner.
I have a friend working in a store that will notify when the distribution begins.
All receivers with slot FBC can use these tuner, if the manufacturer wants (of course).
The VU+Zero 4K model has a simple DVB-S2X tuner (only 1)
Tengo un amigo que trabaja en una tienda que notificará cuándo comienza la distribución.
Todos los receptores con ranura/slot FBC pueden usar estos sintonizadores, si el fabricante quiere (por supuesto).
El modelo VU+Zero 4K tiene tuner DVB-S2X sencillo (solo 1)
Archive-8
You could build a little server, running Linux that can do multi stream. + 4:2:2 oh and you would be able to blind scan.
Just a thought:Y
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Just a thought:Y
I've got about 7 PC's here as it is, I must have a STB and then I'll mess around with USB/PCI tuners, but need a STB first up and running :)
