Listen Up Octagon SX88+
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Problem has been fixed in the new update :D
From reading the release notes it looks like they have updated the video driver and from early impressions I can see the playback is working perfectly. I remember someone else said they were having issues on satellite feeds, this should be fixed also.
They are really quick to sort stuff out, have to be fair!
Agreed. But it also looks like it was rushed to market without sufficient testing, as there have been so many new software releases to resolve a great many issues that perhaps should not have relied upon early adopters to identify.
The Edision Primo, which is a remarkably similar product, doesn't suffer in the same way.
Nevertheless, credit to Octagon for listening and acting - There are other brands that don't seem to give a sh1t once the product hits the market!
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Interesting regarding the Edision, do you know if they have released or are releasing updates for it though?
As far as I can recall, there has been one update - and no significant feedback about bugs. People just seem to find it, well, works. Innit.
mikeisyou
Feed Hunter
England
Anybody else curious about the English-DTS soundtracks on some channels. On all of my other receivers the option doesn't even appear but on the Octagon it shows up but the sound doesn't come on. Are there many receivers that support DTS audio?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Whats it plugged in to, the TV or a AVR? you might need to change some settings.
mikeisyou
Feed Hunter
England
It's plugged straight into the TV, I've had a look at a sound settings on the TV and none of them want to work with DTS.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Is there a setting on the box to convert to PCM or anything like that?
mikeisyou
Feed Hunter
England
On the receiver end I get the option of Bitstream or PCM and on the TV end I get the option of PCM or Auto, none of the combinations work. I got this response back from Octagon "DTS should work but needs testing". I have a bose system and a new tv I could try it out on but I'm highly doubtful.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Depends if the SX88 can convert it or does it just pass the DTS stream through, it might need a decoder on the TV/AVR.
Let us know how you get on as I don't have anything that will decode DTS.
stephan94
Bavaria
Hello.
he also had some big problems in the beginning.
With SW 1.04.39 almost nothing worked: no multistream, no DD.
Now with 1.04.48 it's OK.
Say the Edision Primio s2 did not have a problem,
it's not really accurate.
stephan94
Bavaria
My bad .
when I wrote Multistream, I forgot to add T2MI.
it did not work at all (at least in the person who owns the edision).
Now with 10448 everything is OK.
mikeisyou
Feed Hunter
England
I've just tried through the bose 321 system which is about 12 years old and couldn't get any sound through that even though in the specification it says it supports DTS audio, it doubles up as DVD player so it could be for discs only, it also doesn't support DD+ either but that can be fixed by switching to bitstream. Via the TV DD+ works but DTS does not, although the specification says "DTS Digital Surround" is supported. Spec for TV - Sony A1 4K HDR OLED TV with Acoustic Surface™
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Is it a DTS or DTS+ Channel mate?
mikeisyou
Feed Hunter
England
On the Octagon it just says English-DTS, so I'm presuming just regular DTS. The channels with DTS audio are Channel 5 HD on Astra 2 and France 3 multistream on 5w
mikeisyou
Feed Hunter
England
Anybody else with a SX88 or SX88+ having problems with the RTSH transponder on 16e (12639 H 10833)? The signal takes about a minute to lock but once its locked the channels work perfectly, this is the first transponder that I have come across which has this problem. I have no problems on my other receivers so this leads me to think its an Octagon problem.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin + SF8008 SUPREME + Uclan Ustym 4K PRO Twin
GTMedia V8 UHD
GTMedia GTcombo x 2
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Here SX88 using the 'Transponder List' signal 'Quality' seems to jump up and down then a solid lock.........takes some 10 seconds......then changing to another transponder and scanning it and finally returning to 12639 H 10833 (scans in here at 10835) instant lock!
¿So? :oops::unsure
mikeisyou
Feed Hunter
England
Interesting that this info isn't listed on Flysat or Kingofsat. Maybe someone should tell them :D
I made a thread for it
stephan94
Bavaria
Encode_1080P_42.mp4_20180331_080546-tile.jpgFR3 audio.jpgFrance3 11509 H 5 ° west.
In reality Audio: Englisch-DTS, does not exist.
Maybe a marking error?
On all other audio channels there is sound.
Retired human
Hi all, can't ignore this much longer and am thinking of getting this. Two questions though.
Can the signal be displayed in dB (real or not) or only on arbitrary percentage points?
Do you get a signal quality reading under lock like sat cards and F15 receiver?
