TJExcalibur
- Jan 9, 2005
- Age
- 82
- Location
- Out of this world.
- Master Focus 90cm .Gigablue UHD Quad 4K on TM 2600 motor. *Tm 5402 HD M3, *Atemio Nemesis. *Not Used.
- Southern England
Gigablue UHD Quad 4K keeps freezing when doing a service scan. I have tried different images, Team Blue, Vix, Open ATV, all the settings in tuner configuration, different tuner, reset the motor, changed the LNB and redone all the connections. Still the same. Automatic scan on various satellites and it does one or two then sits there doing nothing. If I use positioner setup and scan inn a few satellites it will move to each one, the dish will also move in positioner on go to position. I therefore thought maybe its the Gigablue tuners so I connected my Atemio Nemesis and it did a perfect scan of the 5 satellites I set. Therefore I will leave the Atemio to do a scan of all of the satellites from 50 East to 30 West whilst I nip to the hospital for some tests. If that's OK where do I go from there?
