- Jul 2, 2005
- Location
- Epping Forest
- Epping Forest Essex
How to add active Multi-Stream TV to your Octagon SX-88
The Blind-Scan works fine for finding normal SD & HD transponders,
The SX-88 does not actually find Multi-Stream Transponders with the Blind Scan,
You can activate the current transponders for Multi-Stream that are in your database by making your 1st scan on a satellite with Multi-Stream selected,
How to do it:-
Go to instalations on the satellite that you want to scan then TP list & delete all dead transponders,
Now move to Antenna settings & press OK on the satellite you want to search,
Press the red search button,
Now select as follows in the sub-menu:-
Mode = Auto
Multi-Stream = On
FTA only = On
TV/Radio = TV
NIT Search = Off
Search = Press OK
After this just use the normal Blind Scan without activating the Multi-Stream in the scan to update your database,
If a new Multi Stream starts or a current one is missing from your database then add the data manually from here FlySat Sat List then follow the instructions in the sub-menu above.
How to do it:-
Mode = Auto
Multi-Stream = On
FTA only = On
TV/Radio = TV
NIT Search = Off
Search = Press OK
