Listen Up MIS Multistream Channels: Easy Reference
I've contacted the author requesting consent to post the actual content ..... bit rude to copy and paste it willy-nilly.
gap30
technomate 90cm dish
Liverpool
what do you enter where it says PLS root 8?
5w 12627 for example
You cannot enter PLS root as this is a reading not a setting,
Just add the known frequency & symbol rate then scan for single transponder in Multi-Stream scan.
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
The MS on 12.188 H on 4.8 East is not listed :(
Good spot.
Can you please notify the author using the form at the bottom of the web page.
gap30
Liverpool
I cannot get a sniff off 12627 but other frequencies fine
Although it could be driver/software related....
12627 H 35000 working OK here check your database for errors.
Lumpen
Motorized satellite dish (100 cm). TBS-5925.
Spain
Can you check "enable PLS"?
If yes, check it and then
Type = Root
Code = 8
Thanks to @lovinthetelly for this find:
The Italian multistreams on 12.5W were replicated on Eutelsat 5WA yesterday, so all the French and Italian multistream channels are now on 5W. This will be a good test of whether the Edision etc can tune new multistreams itself, or whether it'll need a software update.
12543H S2/8PSK 34200 8/9 - streams 33, 34, 35, 36 (includes DMAX Italia, NOVE HD, Spike Italia, VH1 Italia, TV8, Cielo, Paramount, TG24 etc)
mikeisyou
Feed Hunter
England
The Octagon SX88 can scan this with blind scan and multistream turned on. 5w now has most of the Italian DTT channels, theres a few missing from channel 60+, these are either carried on 12.5w or not at all.
EPG numbers and the full list of channels can be found at:
Servizi televisivi digitali terrestri nazionali in Italia - Wikipedia
The duplicated (from 12.5W) Telecom Italia Channels on 5W 12543 H underwent an SR and FEC change to 36510 2/3 at some point in the last couple of days.
They then became inactive yesterday afternoon and remain absent today.
No further reports, as yet.
lovinthetelly
Sky+HD, Wavefrontier T90 with 16 quad/octo LNBs receiving 42E/39E/33E/28E/26E/23E/19E/16E/13E/10E/9E/7E/5E/3E/1.9E/1W/5W/12.5W through 3 EMPCentuari 16-way DiSEqCs to TBS6522, Octagon SF8008 & Edision Primo IP S2.
90cm for 7W/15W; 1.2m CM in storage.
At 5W, '20 Mediaset HD' and 'Mediaset Extra HD' have appeared on 12606V stream 2 (8PSK, 35000, 2/3, root8). Canale 5 HD has moved across to 12627H stream 1 (8PSK, 35000, 2/3, root8). Lots of changes due to Mediaset Premium's new offering, and Mediaset's World Cup coverage being split across Canale 5, Italia 1, 20 Mediaset, and Mediaset Extra.
Great info, thanks :Y
.... except there is no signal on 12606 right now :N
or 11179
or 11637
A state of flux, perhaps?
