Pimp up Channel Master
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Plate which is installed now has 120mm between horizontal holes. Of course, it is possible to make wider plate but then system will become less stable. And, anyway, multifeed-rail should be somehow connected to the plate.
RimaNTSS
N-E from Riga
Another try. I think this is more or less final result. Maybe some minor adjustments needed. Someday will do some reception tests. As multifeed is not my priority I made only 13cm between outer LNBs, but distance can be easily extended up to 25-30cm.
Sat1969
CM 90cm
London
Excellent work. Reception tests will be very interesting before we place orders
RimaNTSS
N-E from Riga
@Sat1969 you will get discount as it was your proposal how to attach the multifeed rail :)
Even without tests I can say that reception results on the central LNB will be not worse than with original feedarms and LNB-holder, and that is because LNB can be adjusted in all possible dimensions with the aim to co-locate LNB's Phase center with antenna's Focal point. Reception on multifeeded LNBs will also be as they should be in multifeed.
nelson_b
Contributor
Another work of art - RimaNTSS - ... very nice
It looks good on the pics .... it will look superb in real life ....
the adjustable c band holder rimas c  band  holder.jpg i got from you early this year certainly did :)
RimaNTSS
N-E from Riga
For those who did not see earlier there is collage I made with all needed dimensions (digits are in mm) of several CM dishes. Unfortunately I miss very much Channel Master 0.75m. So, if some of you have it, please, please let me know :)
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
RimaNTSS
N-E from Riga
Little bit reworked multifeed rail, now maximum distance between outer LNBs is 18cm.... do not see need to make it wider. Central LNB-holder now is in the more or less proper position.
RimaNTSS
N-E from Riga
Well, played enough with multifeed installation, but I do not like multifeeds and abandon this idea. However it is possible to make Channel Master dish multifeed capable.
I will go forward with making new feedarms for all my small CM antennas (0.75-0.9-1.0-1.2m). Of course they will have different sizes feedarms. But all the connection points to the dish and LNB-holders will all be same. When finish with small antennas, will think about 1.8m where another way of connection to the dish should be used, but LNB-holder can also be same. In case of using C-band LNB bigger clamp needs to be installed.
P.S. It is time to mow the grass! :N
RimaNTSS
N-E from Riga
Have made bunch of bits which will be attached to the face of the dish and hold the feedarms. They look complicated, and, in fact they are. But I like things to be over-engineered. :eek:
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Wow, these look amazing.
RimaNTSS
N-E from Riga
Even if they look same, but for 1.2m dishes will be using 10x1.5mm pipe, for smaller antennas 10x1mm. M6 nuts will be welded on each pipe-end. LNB-holder will be same for every antenna.
archive10
And how does one place orders? :D
Seriously, though, I have enough project lined up to make a CM120 with new feedarms something that might happen, well, next year?
So, in the meantime, I just sit back and enjoy your projects... :)
RimaNTSS
N-E from Riga
RimaNTSS
N-E from Riga
I am in process of making more or less universal multifeed LNB-holder for an average offset antenna including 1.8m CM. Chap wants to install 2 C-band LNBs and 1 Ku-band LNB on his motorized 1.8m antenna. C-band LNBs will have ~80mm feedhorns, so this multifeed plank should be OK. Will make feedarms out of 12mm INOX pipe, and they will be adjustable in length.
Trust
Nijmegen Netherlands
RimaNTSS
N-E from Riga
RimaNTSS
N-E from Riga
Have finished the set (feedarms, connectors, multifeed with 3 holders) for a friend of mine. He will be installed all that to nis NSC1.8m and later to CM 1.8m. Dishes are different but length-adjustable feedarms will allow proper adjustments. Yellow wire has 1830mm and 1080mm marks - to place central LNB exactly in antenna's focal point. Feedarm pipes are 14mm in diameter.
satelliteman
Nice work there. Well engineered.
RimaNTSS
N-E from Riga
Friend of mine has sent me PM he does not need anymore. Of course it is rusty and looks ugly, but all the parts are there. One M8 bolt was broken inside the hole, so it took some time till I got it out. There is no thread anymore, therefore I've drilled 8mm hole through the square bit and long M8 bolt will be used to hold the upper part of the PM. Then I cleaned rust little bit, got bored and put PM in the box till I get the right mood to continue.
