- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
Finally got the new runs of coax I wanted, one is for the 1.5 dish, 1 run is for the lnb Changer, 1 run is for my radio scanner/sdr also added some 4 core cable for the motor.
Plus I managed to pop the conduit cover back on in the lounge. (You would never know it’s been off)
While I was in the loft I found the rf distribution amp and found it is not dab compatible so I have ordered a replacement that will allow dab.
Now I just need to pop that aerial up
It’s slowly starting to progress forwards.
Tbh I'm not sure DAB is good to have running through the system with all the other requirements at the other bands.
Are you checking all the signal levels are similar before they combine?
