ses astra first signal 8k 23.5 e
June 29 brings extremely interesting information for those interested in 8K tests. The SES operator, which in the second half of May carried out trials in 8K resolution from the satellite Astra 3B (23.5 ° E) on the occasion of SES Industry Days in Luxembourg - is again conducting trials at 8K. This time they are implemented from the position of 28.2 ° E, but more importantly - within them, materials prepared by the Poznań Supercomputing and Networking Center (PSNC) are broadcast.
For the purposes of the issue, an unused 40 Astra 2E satellite (28.2 ° E) satellite transponder was activated, operating in the European bundle, with the following parameters:
Astra 2E (28.2 ° E)
tp. 40
frequency: 12,480 GHz
polarization: V (vertical)
SR: 30000 ksymb / s
FEC: 3/4
DVB-S2 / 16APSK
Roll-off: 0.2
Pilot S2: Active
The transponder in this configuration offers a net rate of approx. 86.719 Mbit / s. The signal in Poland is quite strong, although weaker than it was when testing with 23.5 ° E. The use of 16APSK modulation forces to ensure a higher level of signal-to-noise ratio than for classic DTH platforms (eg Sky, emitted from the same satellite position). It must be over 10.21 dB.
The configuration of the broadcast is the same as it was in May, again it is a DVB-IP stream, after trying to search on a regular receiver we will get an unnamed service
ID: - (missing)
PID Date: 3000
SID: 100
PID PMT: 4000
After filtering it, we will get another transport stream from video in HEVC, without sound.
ID: - (missing)
PID V: 1023 (HEVC / UHD 8k)
PID A: - ()
PID PCR: 1023
SID: 1
PMT PID: 255
Image quality: 7680x4320, 16: 9, up to 81 Mbit / s
The five-minute recording after filtering took about 1.73 GB. Similarly to previous tests, the bit rate changes with high dynamics from 0.5 Mbit / s to over 81 Mbit / s, and as a result the amount of data may be smaller.
The frame from the test transmission in 8K implemented from 28.2 ° E
After clicking, you can download the lossless screen shot in full quality (7680x4320), but be warned that it takes 79 MB!
The editors' great joy was the fact that this time, as part of experiments, materials in 8K resolution were broadcast by the Poznań Supercomputing and Networking Center (PSNC), in the material under the English name of PSNC.
It seems that these are the materials mentioned during the previous 8K tests (then they could not be observed) from the PSCC - short film impressions realized in the Poznań Palm House and in the PSNC studio: Palmhouse 8K and Magda 8K.
This is the title of the Polish test accent mentioned in the title, the SES satellite operator is responsible for the broadcast.
MCelliotG
Thessaloniki, Greece
Can anyone report if this frequency is received with HD51 in any constellation (report signal)? I think we have a bug here!
ocean04
Vaasa
Western Finland (63N 22E)
2E 12480V requires strong signal. This morning barely above lock 12db Octagon SF4008 + 3m
MCelliotG
In Octagon there is no problem lock 16APSK, but I need some confirmation with HD51, I think they messed up constellations big time!
stephend2017
KU Band: Motorised 1.2m dish connected to a TBS 6981
KA Band: Eutelsat KA-SAT 9e on Ireland spot beam connected to a TBS 6904
Ireland
anto@
italy
my signal
Anonymous_1
The result is better with LA player instead of MPCBE for a live stream over the LAN
it doens't crash
PS: edit not full size screenshot (too large)
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
it doens't crash
Never heard of LA Player, but no luck with MPC-BE here, only could get a picture in MPC-HC.
it doens't crash
please upload more photo
the video ts it also crash
12480 V-player PotPlayer.All CPU resources are at stake...
Thanks @Dave5118
Dave5118
Vu+ Uno 4K SE
Edision OS Nino Pro
Sky Q Silver
Nr Manchester UK
The SmartDVB player consumes less resources than all the players used so far.
MCelliotG
Can someone upload a TS file of the 8K video, I'd love to see it!
meny thanks about photo
Excellent work SmartDVB with the 8K streams,smoothly,without stuttering,as usual.It must be said that the video stream is short and repeat continuously,so there are not many pictures to captured.
You can download the 8K stream from Here
[U]satesco[/U]
thanks about the photo
any more photo of 8k ?
