What do they do, the polarizer was bolted on the back of the center boss with the LNB bolted on the polarizer. The problem I have is a C120 lnb won't fit onto the bolt holes.On first two pictures it is electromagnetic polarizer - old stuff. I have the same somewhere.
Water and LNB electronics "don't like each other"It's going to wreck the LNB feed and your viewing choices unless you fit a water cooled additive.
Racal has been doing it for years.
Really messed up with this design for consumers, but hey! They sold a few thousand duds along ppt the way.
Communication Services via Satellite
Ferrite LNB polarisers were very useful, especially before modern high power sat transponders and low noise LNBs, because you had a lot more control over the actual skew angles used - you could adjust the polarisation "little by little" to home in on the best angle for receiving a particular transponder, and then store that on a transponder-by transponder basis in the Rx. Used that a lot on the NEC 5000 Rx "in the day"
Early voltage-controlled polariser LNBs were, by comparison, very crude, and at the time I regretted the compromise that just gave you the "H" or "V" options as you couldn't then optimise received signals without physically turning the LNB (even though it substantially reduced the Rx & LNB circuitry, and needed fewer cables between the two).
I will have another look tomorrow, when I tried to fit the C120 lnb without the polarizer the holes did not appear to line up.
