Advice Needed TT1260
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
Anybody know of this, I bought one from ebay, for 4.2.2 feeds, looking at it, I think I have more chance of playing for Man Utd, than getting apicture from this box.
Don't even know how to start.
mariust5
Cristor Atlas 100HD , motorised 1.1 Triax on Stab H-H
hastings , uk
As far as i know that's SD and all feeds now are Mpeg4 .
No remote control or TV on screen menus from that bad boy. It will do 4:2:2 SD feeds if there are any left up there. Everything is done using the buttons on the right side of the front panel in conjunction with the small display screen. You have to manually enter the voltage to change the polarity and also manually enter the frequency.
If you have multiple LNB cable inputs on the rear panel, you need to specify in the menu system which connector the TT1260 should look at for the signal. Once you have entered the required signal parameters correctly, the little red dot light on the left of the display screen should turn green to indicate you have a signal lock.
You can connect it to a TV using and SDI to HDMI converter by connecting an SDI cable to the middle connector on the bank of 5 rear connectors, it should say SDI output underneath it. You can also use the CVBS connector with an adapter to connect to phono or scart sockets for connection to a TV.
What is the date of your trial for Man Utd?
