Saorsat Signal Changed FEC 2/3 from 1/2
zg3409
All sorts
Ireland
Some people are reporting the signal for Saorsat has changed. It used to have the error correction of 1/2 FEC but it now seems to have changed to 2/3 FEC. On some receivers this would not seem to make any difference as it normally finds the correct setting in Auto, but on other receivers you need to manually set the correct rate. The frequency and polarisation is the same.
Mark Hargrove
80cm motorised dish with Tm5402 receiver, sky dish with sky hd receiver, freesat in 2nd room
Bristol
Cheers for that, good info
Retired Mod
www.timo.me.uk
I suppose that will tighten the footprint even further since the higher FEC will make it a bit harder to lock at the fringes.
I guess those on the edge of footprint with weak signals might lose their RTE fix...
JOHN896
Swansea UK
Channel Master 2.4m Dish Fixed On 9.0 East Ka Band.Channel Master 1.2m Dish.Satellite Reception From,53.0E-45.0W.
Swansea Uk
No change here 2.4m dish 99% signal,1.2m dish 75% signal.
Mark Hargrove
Bristol
Cripes that is a BIG Dish, no chance of you loosing those Irish Channels
JOHN896
Swansea UK
Swansea Uk
I don`t think i would ever lose the signal on the 1.2m either.
Retired Mod
www.timo.me.uk
When the FEC changes it's the % at which the breakup occurs that will be different. So before breakup might have occurred at say 40% with a FEC of 1/2 it might now start to breakup at 45% with a FEC of 2/3 but the signal quality will stay pretty much the same. These numbers I used here are just an example, and will change from receiver to receiver.
Fisty McB
See my signature...
County Tyrone, N. Ireland
From what I understand Saorsat reception is more limited by interference from other spot beams on the same frequency than by signal strength. I would say that if you're receiving Saorsat in any part of Ireland, north or south, you're not likely to notice much difference in reception if you stuck to the recommended dish size. It's reckoned that Saorsats transponder power is currently lower powered than what it could potentially be, some people who monitored early testing noticed it being much stronger than it is at present, so they could be able to turn up the power to compensate for the FEC change.
I'd guess the FEC change is to prepare for RTE1 to go HD on Saorsat, as it has been on Saorview now for a few months with the SD simulcast about to be turned off.
I might get a Saorsat LNB for a bit of messing about later on, but I can already get Saorview terrestrial transmissions fine so Saorsat wouldn't give me anything I can't already get.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I've never locked Saorsat here in Manchester ..and have tried on many occasions with various dish sizes ..
The (assumed) scottish beam ..had in the past given me something at his frequency that resembled a lockable signal ..and blocked any possibility of receiving Saorsat..
Now I get neither ..and have gone up a dish size to 1.5mtr..
Dish size is not relevant to reception imo ..in fact the larger the dish ..the greater the problem if you are out of footprint...which I am.
The combination of reduced power ...changed FEC and overlapped footprints make reception of Saorsat here even less likely than it ever was.
Tricky back then ...
Impossible now....
At my location.
rgds
VS
Pride Of Cucamonga
Valencia (city)
Are these higher FEC rates because KA band more susceptible to rain fade? Anyone know what FEC rates DirecTV use for their Ka transponders?
dramirez
1.8m dish for DirecTV 101 (trying to get Ka on 99&103)
Zacatecas, Mexico
Ku: 6/7 & 2/3.
Ka: 2/3, 3/5, 4/5 & 1/2 for Reverse Band.
fereshte
Bulgaria
2,30m prime focus dish with 3 LNBs - C ( Linear plus Circular ) and KU ( Linear ) ; 2,05m prime focus dish - KU circular and in future hopefully - ka band - 103E - 50W ; Octagon SF4008 UHD ; Edision Primo IP ; Inverto Flange white series ; Invacom quad; 36" motors; Especta and Moteck satellite positioners.
Bulgaria
Hi, in your opinion is it possible to receive RTE package on ka band with 2,04m prime focus dish in Bulgaria ?
No chance whatsoever!
One of our members in Manchester (north west UK) has tried it several times and could not get it due to a co channel frequency on a different spot. The RTE spot beam just about makes it into central Wales & over onto the North Devon coast..
However dont let that stop you trying - freak reception does happen & all the members here would be delighted to see you succeed! :D
fereshte
Bulgaria
Bulgaria
If I find a LNB KA SAT for 9E and 19.2E certainly I am going to make some tests.
Hi, just remind me what you wanted to view from 19.2E please
fereshte
Bulgaria
Bulgaria
Nothing special at all, just for the reception and the test itself.
Tsiklon
Various
Europe
Dr Dish/Christian Mass conducted a test with a 13M dish in Germany, and was unsuccessful, so I wouldn't be betting much on a 2M dish in Bulgaria
Report starts at 3:45
The biggest problem with the 9E Ka band frequencies is that there are multiple beams using the same frequency - specifically designed to block out of area reception.
fereshte
Bulgaria
Bulgaria
Understand, so it is irrelevant to test 9E KASAT from Bulgaria.
