New Edision OS nino Pro Grey 1x DVB-S2X + 1x DVB-C/T2 Linux Enigma 2 Combo Tuner Digital Multi-Stream Receiver H.265 HEVC HD 1080p
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
You may leave the plugin.py file, but probably best to remove it for future updates.
OK scanned Ka 19E it works! my LNB is LOF17250 but the found channels are a 100Mhz out Newsnet should be 11.558. but it looks promising!BS1.jpgBS2.jpgBS3.jpgBS4.jpg
@scopus if you tell the receiver it is a universal lnb, scan 10700 to 11700. What frequency does it show the transponder is at???
10.558 Huevos, I still used the user defined option set at 9750
stephan94
Bavaria
Another small question:
How can I get the channel number instead of the time on the front of the OS Nino Pro ?
I can not find it in the menu. :(
World-of-Satellite
VU+ Ultimo 4K
GiGaBlue UHD Qaud 4K
GiGaBlue UHD UE 4K
VU+ Zero 4K
No longer possible without reskinning the display , an old plugin used to have the option but this used to use more cpu. A solution was introduced for all 7 segment displays that removed the plugin.
stephan94
Bavaria
Hello,
with today's version 5.02.012, the blindscan does not work at all.
Encode_1080P_3.mp4_20181114_132448-vert.jpgEncode_1080P_4.mp4_20181114_134941.611.jpg I went back to the previous version 5.02.011.
What had you set the LOF to when you opened that blindscan page? The reason I ask is, with Newsnet being a 100 MHz out in the test version last night, I set the LOF to 17350 in the tuner config hoping that would correct Newsnet readout, I opened blindscan and got a blank page as you have posted. When I set the LOF back to 17250, the blinscan page was OK again. It was all OK with SATs set at universal to.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
There is nothing wrong with blindscan in 5.02.012 using normal lnbs. So try online update.
2 MHz transponder spacing in blindscan is also available in the latest OpenVix update.
stephan94
Bavaria
Hello el bandido
I made an update by USB.
Excuse me but where is an update made online?
Unfortunately I do not know it. :(
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Follow this path in the receiver menus:
Menu--->Setup--->System--->Software update
Hello el bandido
It will be in 'software management' in the menus then choose 'software update' you should then see a traffic light symbol which should be green they you are good to go..
Although i don't use these receivers myself for Ka reception i have to say that you are all doing some great work here advancing the functionality for all to benefit :-respekt
Enigma 2 has come on along way since I last tried it in the AZboxes, especially the blind scan!
Newsnet should read 18.558 sorry..
Your posts don't make any sense. Set up the tuner as universal lnb and do a blind scan. Post a screen grab of the found channel showing the frequency.
I don't need to post a screen grab, the returned frequency is 10.958 for Newsnet with a scan from 10.700 to 11.700 set in the blind scan that uses the LOF of 9750. I have scanned this many times so know this is correct.
