- Aug 10, 2008
- Romania
I hope you can clearly see the mobile antennas located in the vicinity of my antenna.Because of this all the reception in the C-band is almost compromised.That's why I have to look for an anti-interference filter.I found such filters at Norsat,here sau here.
Of course there are other filters from other manufacturers,but I don't know where to find what I need.That is why I hope that they will be enthusiasts on this forum that have had such problems and that,who knows,may have found the right solution?
I would be very grateful to the one who can recommend a suitable filter to attenuate as much as possible the massive interference from the mobile antennas seen in the picture. If you use such a filter I want to know what experiences you have and/or if it helped you?
Any suggestion or advice is welcome.Thanks.
