12 304 h on astra 28 e - which satellite and beam?
Nalleman
Motala Sweden
Sweden
12 304 H is activated again but this time it's much stronger than the previous time this transponder on the UK beam was used.
The level is about the same as the European beams on 2F at my place. Is 12 304 H now transmitted on a European beam?
Lyngsat and Flysat says UK beam on 2F but if so I can't get why the level is so much higher now.
Before the switch off the level was around 8 dB and now it's around 14,5 dB som my absolute conclusion is this is now a European beam.
Nalleman
Motala Sweden
Sweden
I'll answer my own question above! 12 304 H must still be on 2F but on a European beam. 2E and 2G are much stronger than 2F even on the EU-beams. 2G is almost extremely powerful at my place.
So strangely enough 2F seems to be able to do 12 304 H both on a the UK beam AND on the EU-beam but not at the same time of course.
Reception of the EU-beams looks like this at my place in the southern parts of Sweden:
2F 14.5-15.5 dB.
2E: 16 dB.
2G: 16-20 dB. Most of the TP:s 19-20 dB but 11 553 H just around 16 dB.
ocean04
Vaasa
Western Finland (63N 22E)
12304H was previously 2E UK (not 2F UK) Now it's 2F Europe.
Difference between 2E (28.5E) / 2F (28.2E) is really easy to see here (3m)
Tururu
Assembled with recycled parts
Recycled as the owner.
Similar for Madrid (Spain), I sent the theme to flysat the other day when Hendrik fished the channel, he does not see the UK beam.
2F UK ==> 2F Europe
The difference in levels is important.
Similar por Madrid (españa), les mande el tema a flysat el otro dia cuando Hendrik pesco el canal, no ve el haz UK.
2F UK ==> 2F Europe
La diferencia de niveles es importante.
Nalleman
Motala Sweden
Sweden
Flysat and Lyngsat updated now!
Not at all unexpected - we have known all along the three birds can all cover for each other. SES couls have a total failure of one of the 28E birds and suffer no great problems. Therefore the transponders must be switchable between beams to a great or lesser extent
lovinthetelly
Sky+HD, Wavefrontier T90 with 16 quad/octo LNBs receiving 42E/39E/33E/28E/26E/23E/19E/16E/13E/10E/9E/7E/5E/3E/1.9E/1W/5W/12.5W through 3 EMPCentuari 16-way DiSEqCs to TBS6522, Octagon SF8008 & Edision Primo IP S2.
90cm for 7W/15W; 1.2m CM in storage.
Hi folks,
Could somebody outside the British Isles please check 12012V and 12090V (DVB-S2, 8PSK, 27500, 2/3)?
These transponders are carrying the 3 new STV HD regions, which are now FTA. I'd expect the TPs to have switched from the European beam to the UK Spot- has this happened?
4wd
Getting the picture
5 W, 9-13-19-28 E
^^^ both freq. full blast EU beam.
lovinthetelly
Interesting, thanks.
I can't see this situation lasting - either they'll encrypt again or the TPs will switch to the UK spot.
But for the time being, enjoy a strong STV/ITV HD signal!
Dont be surprised if you are looking forward to some big name ITV drama or big football game and you tune in to find STV is actually showing International Haggis Hunting or some other dross - they are notorious for opting out of the ITV schedules, & annoying the viewers with some home made piffle!
Nothing wrong with haggis, I'm hunting one down tomorrow.
MCelliotG
Thessaloniki, Greece
Coming through in Greece shiny and clear! Nice to see some HD live English TV again after all these years, even though it's not gonna last!
lovinthetelly
Sky have recently re-activated two DVB-S2 transponders that were cleared a few weeks ago.
Could anybody check if the following can be received outside the UK spotbeam footprint?
12168V 27500 8PSK 2/3
12363V 27500 8PSK 2/3
These transponders carry the additional STV HD regions that launched FTA on the European beam last year, before being encrypted. I suspect they may be going FTA if the TPs are now on the UK spot.
EnoSat
enosat.euweb.cz
Slovakia
in central europe not find this freq (but unknown signal on 11739 V) , Satindex too write about UK spot
lovinthetelly
Thanks - looks like the encrypted STV HD regions will be going FTA.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
N 60.517691, E 14.277809 Not a glimmer.
4wd
Getting the picture
5 W, 9-13-19-28 E
West coast Norway 1.2m
12168V 27500 8PSK 2/3 10.5 dB
12363V 27500 8PSK 2/3 8 dB
Evening drop + bad weather. For reference, 10906 10.5 dB
Nalleman
Motala Sweden
Sweden
Southern parts of Sweden in really bad weather (heavy rain) 1,8 m:
12168 V: 8,2 dB
12363 V: 7,8 dB
Seems to be weaker compared with many other TP:s and at the same level as 12129 V and 12382 H.
dmaavrigdo
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
This has opened a can of worms! My nano M3 sees 12168 at 10db the Zgemma H9s sees nothing.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
From all recently mentioned frequencies I have only 2 receivable namely 12168V and 12129V . Do not forget that during the day signal levels can change a lot, especially if we speak about fringe reception areas. The daily changes of signal level can be up to 2dB.
