This Is News To Me. Stab HH100
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Thanks, RustySpoons. I will check that.
Also the collector pin of transistor Q2 seems to have been hot (it's a bit blackened). Could that part of the circuit have something to do with the burning of R20, too?
Photos of my circuit board with burnt R20 can be seen at the dutch forum: STAB HH100 onderdeeltje doorgebrand
Also the "dossier technique" of the HH100, complete with circuit diagram, is there: It's not too large to be uploaded to sat4all.com!
And another forum member has reported a motor with a defective R20 there. Is the R20 not dimensioned well in these motors? Should it have a greater resistance value, or be able to handle (dissipate) more power?
greetz,
A33
I read the post on the other forum you just linked to, when I said it's there for current limiting its to limit the power drawn from the STB, especially if there is a fault condition. The 7805 doesn't need it normally, however it can sink 1amp (Or more depending on flavor) which you do not want on your STB!
Check Q2 to see if it reads correctly on diode setting with multimeter, resistance setting will tell you if it's completely gone however but will not show if it's functioning.
When you fit the replacement R20 stand it up longer on its legs so it's off the PCB, it will get better airflow, not char the board and the legs will also help dissipate heat. No harm in going up with current capability, i.e. 1w instead of 1/2w etc (Not sure whats fitted). But I wouldn't mess around with the value.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
I'll have a look what I have lying around at about 40 ohms.
But right now I've got some nasty flu.... :(
After checking and replacing, I will check the temperatures of the components too, while attached to my STB.
Greetz,
A33
I would advise installing 2 x 75 or 2 x 82 Ohm resistors in parallel (if they fit), which gives the user an indication of impending falilure of the Stab rotor when one goes open circuit down the road.
a33
XSAT410
Rebox RE-9000
The Netherlands
Likely it's used as a current limiter, I should imagine it's just burnt out eventually. Nothing to lose replacing it. Check the regulator hasn't gone short.
While still on the circuit board, the 7805 has about zero resistance between output and ground.
Not good, is it?
I'll have to desolder it, to check?
Or can I put a 5volt (or so) voltage to the input, and check what output voltage is there?
Q1 and Q2 seem to be no problem (BE of Q1 shows low resistance, but that is not bad because of R4 < 2 ohm?).
Though all this is a bit hard to measure, as they have sprayed the circuit board with a thin layer of I don't know what. (After repairing, should I also spray it with something?)
By the way I've "isolated" the schematic pages of the STAB HH100 rotor of the former mentioned document: see attached.
greetz,
A33
  • STAB schema HH100 printlayout Uit DOSSIER_TECHNIQUE_ROTOR_STAB_HH100_d_ANTENNE_PARABOLIQUE-1.pdf
  • STAB schema HH100 Uit DOSSIER_TECHNIQUE_ROTOR_STAB_HH100_d_ANTENNE_PARABOLIQUE-1.pdf
Not good, is it?
greetz,
A33
If there is only one component following on the output rail, disconnect that rather than the regulator.
You might find a diode further downstream that has gone short circuit.
a33
XSAT410
Rebox RE-9000
The Netherlands
No, there are about 10 components connected to the 7805-output directly.
And no diode downstream. See the schematics (the 7805 is the U3).
Maybe I'll try, after desoldering the 7805, to apply an external 5V source there, to see if the rest of the circuit is functioning properly.
When also another IC is defective (e.g. LM239), repairing would be too great a task...?
Greetz,
A33
The schematics didn't show the tracks under the circuit board, though the second image does show a test point, I assumed there might be a link wire before it, normal practice in PCB power design.
You could cut the track of course, then wire bridge later (or leave the full leg of a new regulator to do the same job once passed through the PCB ).
Terryl
Custom built PC
I would remove the 7805 IC then remeasure the DC resistance at the +5 output, if still at zero ohms then there is a shorted IC or other component (capacitor) somewhere on the PCB, I would not put an external +5 power supply to the board in place of the +5 volt regulator, unless it is a current limited power supply, you may/could damage something beyond repair.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
These are all cheap jelly bean parts, just replace them and the 7805. Will cos you more in time fault finding than fitting parts.
a33
XSAT410
Rebox RE-9000
The Netherlands
Did some testing: shortage to ground in the 5 volt line.
I did cut tracks after the L7805, and after the VCC-pin of U2, and the shortage was in the U2-part.
So I guess the shortage is in U2 itself, as was the case in a STAB motor that @Trust1 tested (see the thread in the sat4all forum).
So I'm afraid that's too difficult to repair for me! :(
Unless changing the whole circuit board; that would be doable. But they are not for sale, I believe?
greetz,
A33
Send TJ a PM, he may still have the faulty Stab rotor since it was never replaced under the warranty.
Even though it shares a common failure to yours it could be useful for,stripping down to identify the second board fault and the cause.
jdann
VU+ Duo 4K SE, 1.1m Nokia dish
Suffolk
Random question - what size socket works to undo the nuts on the connectors so the PCB will come out?
So far I've tried various 10mm (don't seem to fit the nut) and 11mm (won't fit inside the casting to get at the nut)
Mines an old 2002 unit, was fine last time I used it but it needs a bit of a clean...
Trust
Nijmegen Netherlands
Its 11 mm , you have to machine down the outside diameter of the socket
They will undo if you lever them anti-clockwise with a small flat-bladed screwdriver (and can be done up the same way)
Magmax
Croatia
freesattvforum.createmybb4.com
Nytrobox 6000 HD Combo 90 cm motorized dish vith a Engel Digi Trekker motor
Croatia
Hi it could be that the rotor dose not work well vith your receiver, It might be llocked in limits, I have aloso heard that when they break they return to zero position automaticaly.
