Nalleman
- Mar 28, 2008
- Location
- Motala Sweden
- 1,8 Channel Master, Black Pro LNB with CM feedhorn for 28 E which is my main interest when watching TV. VU+ DUO 4K SE, VU+ DUO 2, Octagon SF8008 and Vantage 8000 S and TS receivers. Fixed dishes at: 42 E (0,75 m), 28,2/28,5 E (1,8 m), 19,2 E (1,5 m), 13 E (1,1 m), 9 E (0,7 m), 5 E (1,2 m) and 1 W (0,7 m).
- Sweden
Most of you guys living in UK probably do not see any changes in reception of channels from Astra2E (UK beam). But we, who have to enjoy fringe reception feel that something is going on with satellite. Firstly, the levels of signal are increased, and daily variations as well. I have recorded signal levels from 10714H for 24 hours (each 13 seconds) and from data built this graph. If you compare this graph to the same graphs which I made 2 years ago it is possible to see some similarities and maybe also tendencies.
One thing I have noticed is that 12382 H is much stronger than it used to be. Most of the time it was almost impossible to get it here in southern parts of Sweden but now it comes in at between 9,5 - 10,5 dB 24/7. It is now stronger than 12129 V which is by far the weakest TP here. One can suspect 12382 has moved from 2F to possibly 2E.
