Hungarian tv
Lee graham
Hungarian tv
Bridgwater
Hi. Does anyone know how I get a card for the FTA Hungarian channels on eutelsat? Many thanks
Adam792
Cheltenham
They're FTA most of the time (as long as programmes without rights issues are being aired), I'm guessing you watch them on Eutelsat 9ºE with a FTA satellite receiver? Duna TV/M1/M2 etc.?
To be able to watch the encrypted programmes, you'd need a card from MTVA/Duna and a Conax-compatible receiver or Conax CAM (your receiver or TV with satellite tuner must have a CI+ slot to be able to use a CAM). I don't know where you can get the cards from online, but presumably they are available to buy in Hungary if you have friends/family there? The card would be bought from Duna/MTVA themselves I guess.
Cards / cams must just be from Hungarian contacts - I cant recall ever seeing them available in an online shop.
Lee graham
Hungarian tv
Bridgwater
Yes I’m on eutelsat 9e, but DUNA and M1 are still coming up as scrambled even tho I am set on the satellite. Is there a specific box needed?
4Himdj
1.2 Laminas Dish
Rome
I've it
I write you in pm
regards
Both of those channels are marked $ but are in fact Free to Air like most of the Hungarian TV here,
Some Football matches are encrypted.
Lee graham
Hungarian tv
Bridgwater
Yea I thought that, which is why the scrambled message is extremely puzzling to me.
Lee graham
Hungarian tv
Bridgwater
Thanks for all the info above but I am still unable to receive those channels. My dish is set to 9e with a good signal as it picks up the DUNA and M1 channels, however they all say scrambled. Is there a firmware update on my box that could be the issue? I am using a spiderbox 7000.
4Himdj
1.2 Laminas Dish
Rome
It s
hello Lee please re-scan 11958 V 27500 check again you can find in the list double version of the channel. e.g. m4sport and m4sport $
if you receive that tp you are able to receive all the channels of the tp
best regards
Lee graham
Hungarian tv
Bridgwater
It s
best regards
Hi. No I am only picking up the $m4 sport version, same with DUNA, they all have the $ symbol next to them?
I will check this transponder out with a SpiderboxHD9900 & get back to you.
Eutelsat 9B @ 9 east all TV clearing earlier this morning except M3
11958 V 27500
M1 HD (Magyar 1) shows as $ but is FTA
M2 HD (Magyar 2) shows as $ but is FTA
Duna HD shows as $ but is FTA
M4 Sport HD Encrypted for Sports even replays
Duna World shows as $ but is FTA
M5 HD (Magyar 5) FTA
M3 (Magyar 3) Encrypted at all times
M1 HD Europa (Magyar 1) FTA
M2 HD Europa (Magyar 2) FTA
M4 Sport HD Europa (encrypted at times due to copyright reasons) on screen message FTA
M5 HD Europa (Magyar 5) shows as $ but is FTA
SpiderboxHD9900 & Octagon SX88+ showing the same results.
Lee graham
Hungarian tv
Bridgwater
11958 V 27500
Ok thanks. I can’t get my head around why mine continues to say scrambled service.
rodscha
on many receivers you choose between "FTA search" OR "$ search"...(encrypted/premium...)
these channels should be searched as an "$ search" ,otherwise ,they ll be ignored by an "FTA search";
the ident will read "$" but they 'll be FTA all the same
Try deleting transponder 11958 V 27500 then add it & re-scan All on this transponder.
Adam792
Cheltenham
Make sure you're using the services labelled 'Europa'. They point to the same streams as the ones that are marked as encrypted, but are flagged as FTA (they also switch to showing a 'no international rights for this programme' message when an encrypted programme airs on one of the channels).
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
I'm watching with Linux Enigma2 HD receiver the hungarian channels, they all just work fine.
vv
vv
