Ebs pro website down. where to download?
dishdx
www.dxing.cz
Showbox Vitamin, Octagon SX88
Dishes: Offset motorised 120 cm 40W-75E IBU Twin, Channel Master 180 78.5E-30W manual rotate , Cahors BigBisat 8 x Alps 1W,5E,9E,13E,19E,23.5E,28.2E,39E. Planty of equipments for FM and AM DX. http://www.dxing.cz
Central Bohemia
Hi! EBS prop webiste is down. After handy reinstall I need download EBSpro Mobile apk.... I don´t see it at google play... Does somebody have instalation file?
I hope it's what you're looking for here: EBSmobile
dishdx
www.dxing.cz
Central Bohemia
Many Thanks for help!! :-)
EBSPro back on line now
new EBSpro Beta v.17.0.0.1-17.04.2020
Info about new version:
- Added support for *BISS-1 and DCW using VLC as video player. Also reports in status bar if the key is set when playing a stream.
- Added a more visible option to add a transponder manually to the favorites list with the context menu.
- Fixed the way that keys are sent to vlc.
- Fixed a problem saving profile scans (thanks to @alek and @paolo for reports)
- Some minor bugs are fixed.
- StreamReader updated to version 1.2.4.96.
* "asdf" is the way.
frankviana
Satellites/tv
Brazil
We need to solve stable MIS. Using ebspro, example 8w, we don't have option to choose which MIS, only random mode.
TBS 5520se don't work too. Here, using blindscan, repeat a lot of transponders. I have problem using diseqC 1.1 EMP.
Now, for all tests, I'm using crazyscan: Option to choose MIS, blindscan and diseqC working.
Thanks.
Paolo71
Gibertini 100cm, STAB HH120, Inverto BU 0.2dB, Laminas 120, Moteck SG2100A, Inverto Premium 0.2dB.
TBS 5925, Edision OsMio 4K plus, AZbox Premium HD+, pc AMD FX8350 ram 32Gb. IQMonitor Pro, EBS Pro, Crazyscan, DvbDream, VLC and PotPlayer.
Monterotondo (Rome), Italy
Always using EBS PRO, together with crazyscan and Tsreader, but with my TBS5925 I would like to open ACM/Vcm feeds including data and internet carriers like AOL, Ses Broadband, Linkstar service and so many "data" feeds on many satellites. Any help ?
frankviana
Satellites/tv
Brazil
Now, my TBS 5520se working, but no SR 60.000
6922se
5925
MIS (random mode 1 to 4)
Crazyscan we have option to set 1, 2, 3 or 4 to analyze
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
This proprietary data encapsulations :)
Paolo71
I imagine it. Anyway it's funny to find out data feeds through TSreader, sometimes they have MAC addresses and PIDs. Not all of them are the same, depends on the identifier. I keep on searching...
CrazyCat
crazycat69.narod.ru
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
This standard DVB-MPE, handled by TSReader. Hughes networkmodem use some modified DVB-MPE (usual PES dat a identified as AOL data, present PIDs 301,401)
FC GD
Antenna: SelfSat H50D4
Pay Tv: Allente, Telia
Stockholm
CrazyCat
crazycat69.narod.ru
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
EBSpro ALPHA v18.0.0.0 (changelog)-Feb 25, 2022 – NEW!
Thanks @Christian for that :Y
- Added experimental audio/video *player in Signal Analyzer (can be used from SidePanel and from TS Analyzer)
- Added internal PID filtering support (no need to unmark "No PID filtering" in streamreader.ini, now this work is done in ebspro's engine).
- Added link-margin support for SA, Main Window and Positioner (with red-bar autoadjust)
- Show input bitrate in SA. - Improved search field in the SidePanel Scanner (press ESC to clean a search).
- Detect no data input in TSA scanning for SidePanel (this bypass the TSA timeout that takes longer.)
- Added SNR-bar in status bar of main window (also, small redesign of status bar)
- Abort scanning if PAT table reach timeout (don't wait for other tables in this case). This make scan much faster for some transponders.
- SidePanelScanner now stops scanning process faster when is needed. - Improved TCP stream connection handling
- Added support for PLS code in the SEARCH_RESULT structure (Up-to date StreamReader.dll needed -included-, old versions don't will work well). - Detect FFTScan support in Device Info. - Improved support and handling of allsats.txt database.
- Improved handling of device info from streamreader.log and also add temperature reading if is supported by device.
- Fixed a bug that doesn't save/remember the last checked status of the scan ranges.
- Fixed a bug handling TSA Streaming that can make some timeouts scanning dvb tables.
- Fixed encoding mode when handling streamreader.ini file that causes streamreader.dll don't read settings well.
- Fixed MISSel crash and continuous calls to MIS selection function in DT-Mode that make stream unstable.
- Fixed potential crash using diseqc under some circumstances. - Small improvement in USALS calcs.
- Some small fixes here and there. - Update AllSats.txt database.
- StreamReader updated to version 1.2.4.124 (new cards supported: 6902SE, 6904SE, 5930, 6903X(v2), ...)
frankviana
Satellites/tv
Brazil
Here, when finish the download, appear only 1,4 KB.
Do you have the setup file to send me?
stephan94
Bavaria
loading is done perfectly.
For some anti-virus it appears as malware.
this is called a "false positive".
frankviana
Satellites/tv
Brazil
Ok. After disable my antivirus, I have full file.
Thanks.
Frank
Thanks.
Frank
Given the antivirus download issue, I would immediately do an antivirus scan of the downloaded file!!!:rolleyes:
It is a known false positive for some A/V software with the EBS pro exe file. Been like that for years, nowt new 'ere.
I been using it for years, no bad shít happened.
EBSPRO V18.0.0.2 has been release(3.06.2022)​
18.0.0.2 (RC) [3 jun 2022]
- Improved first load time for big databases.
- Reworked how reports are loaded from db (also bugfixing)
- Show and store channels names in blindscan list when sidepanel is in use.
- Added a link to open streamreader.ini to fine tune some option if is needed.
- Added a workaround 'Raw data handling (no use internal filter)' just for experiments and debug.
- Add Wait-0 automatically when setting up an USALS system or Diseqc 1.2 (you can delete if you don't want to use it).
- Reset blindscan result sort by default before new blindscan.
- Improved TS Grabber behavior and small fixes.
- Improvements in Circular Left/Right handling.
- Improved max SNR reset/detection/algo.
- Check TEI status for validate TS packets in Filters handling.
- Fixes in the internal TS handling for some devices that makes stream unstable.
- Fixes and better support for S2X.
- Fixed LOF value not set under certain scenarios, so can show wrong freq values.
- Fixed Blindscan crash if blindscan list is sort and sidepanel is in use.
- Fixed odd/even k*y handling for CSA and small improvement handling k*ys.
- Fixed TSA timeout problem.
- Fixed issue with the signal lost for vertical band after diseqc 1.2 commands.
- Fixed TCP network issues after second connection.
- Fixed a small costmetic bug with Modulation and rollof.
- Fixed video playing issue with chroma subsampling (need test!)
- Sync_counter fixed.
- General small fixes and improvements.
TSA specific (1.8.0.1): Fixes.
